Old 10-12-2005, 11:21 AM
scotp scotp is offline
AC Orifice Tube
Can anyone tell me where the AC orifice tube is located on my 2000 S10 2.2L? I've replaced the compressor and accumulator. Now I'm left with a $2 part that is keeping me from having the system recharged!
Old 10-12-2005, 08:43 PM
tom3 tom3 is offline
Re: AC Orifice Tube
This tube sprays the liquid refrg. into the evaporator so it's located very close to this core which is inside the firewall. Should see a connection in the small AC pipe right near the hvac box at the firewall, unscrew the compression nut and pull the pipes apart, very carefully pull out the tube/screen and note how it's oriented. It doesn't look like it goes back in the way it does, so check it when you take the old one out. Put a new o-ring on the fitting if you can.
Old 10-13-2005, 12:25 AM
dmbrisket 51's Avatar
dmbrisket 51 dmbrisket 51 is offline
Send a message via AIM to dmbrisket 51
Re: AC Orifice Tube
not sure where the orifice tube is located, but, an accumulator on a non charged system for more then a couple of days ruins it, the desicant fills with moisture, so it no longer absorbs what is in the system naturally over time
Old 10-13-2005, 06:17 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
The orrifice tube is on the lower line where the dryer meets the evap in the firewall. Disconnect the line and pull it out..
Old 10-13-2005, 01:04 PM
tom3 - Thanks for the very precise instructions!
rlith - Thanks
dmbrisket - With the help from above, the system was uncharged for a day and a half. I think it's fine.
Old 10-14-2005, 01:39 AM
Re: AC Orifice Tube
youll be fine, and most tec;s will tell you that you will be fine, but industry standard is that if a system is down for more then a 24 hour perioud, an accumulater must be sold for warrenties to be valid
