Go Back   Automotive Forums Car Chat > Ford > Crown Victoria
Old 10-12-2005, 11:09 AM
blackdeathjf blackdeathjf is offline
Angry vic wont go above 80???
i have a 96 crown vic w/ the police package and i would be going down the road and ill hit 80mph and it wont go any higher could someone help me on this problem? thanks
Old 10-13-2005, 09:59 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: vic wont go above 80???
You just named it in upper post. Tune Up.
Like they say sparks plugs to start with.
And sometimes just sparks plugs is called a tune up
The old fashion tune up used to cover checking everything even battery cables hose and belts antifreeze and general look over.
But for a good complete tune up check plugs and fuel and air filter and pcv valve and good idea to check fuel pressure for specs and fuel pressure reg leakage.
Also watch for codes in coomputer system.
And watch that MAF sensor for dirt accumalation.
MT-2500
Old 10-14-2005, 01:16 AM
ok thanks =) i replaced the spark plugs and the wires. i had the oil changed and the oil fiter changed, air filter changed after all that theres a big differance in the power.....i guess i have to change the fuel filter...and clean that sensor.....can someone tell me where the fuel filter is on the 96 crown vic pi....thanks i would be the happiest person in the the world =)
thanks again
Old 10-14-2005, 03:28 AM
TampaTom TampaTom is offline
fuel-filter location
That's a dam good question--hey guys, where IS the fuel filter (mine is '97 P71).......Tom
Old 10-14-2005, 06:38 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Drivers side just in front of rear wheel on frame
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-18-2005, 02:04 PM
cobradude360's Avatar
cobradude360 cobradude360 is offline
Send a message via AIM to cobradude360
yea u cant miss it, its the big round thing with a line going in and a line going out
THE 92 grand marquis LS M75 with the 281 romeo v8 u cant mess with that
MODS: dynomax bullit exhaust, custom intake, polished upper plenum, 180T-stat, accel coil packs and platnum plugs
also 2005 crysler sebring sedan walter p crysler edition yea its got the 2.4 pics comin soon
Old 11-06-2005, 12:47 AM
yogie323 yogie323 is offline
I had that problem before I did a full tune up but you should also check or replace your catalytic converters they might be clough up if you still have the stock one's, if you have four you might want to stay with two leave one on each side the car will run better and should still pass emissions "smog check-test"
