Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 10-12-2005, 10:40 AM
seanish4042 seanish4042 is offline
Warm Air Intake?
Been doin a shit ton of research on intakes. At first I wanted an Injen, then a Stillen Air Charger, blah blah the list continues.
One guy kept posting that a WAI was the best intake mod available.
Can anyone please explain what this is? And where do I get one?
Im leaning towards a frankencar short ram air at this point.
I am also considereing a Warpspeed Y-Pipe...can anyone give me any reviews on performance, installation, sound differences, etc.
Thanks a lot.
Old 10-12-2005, 12:56 PM
Nahkapohjola's Avatar
Nahkapohjola Nahkapohjola is offline
Re: Warm Air Intake?
Originally Posted by seanish4042
......any reviews on performance, ...
Vehicle type?
Check out the best performance per $, semi-WAI : http://www.cardomain.com/ride/748507/2
Intake capacity is its smallest passage.
Old 10-12-2005, 01:00 PM
i have a 95 gle stock
Old 10-13-2005, 04:50 PM
BP2K2Max's Avatar
BP2K2Max BP2K2Max is offline
Send a message via AIM to BP2K2Max
the downpipe on a 4th gen is shown to be the best bang for your buck mod and is said to add 15 whp. when i had my 95 maxima i bought my downpipe from a company in canada called Budget Exhaust. it was $250 canadian, which is like $170 US. i don't know if they're in business anymore, but but a y pipe is definitely the best mod for the money.
an intake is an intake, you're not going to see tremendous gains from one company over that of another so anything better than stock should do. i've heard that CAI's on a 4th gen cause a loss of performance on the top end due to all the extra piping. so unless you were to equip a VI to compensate, you're better off buying a WAI.
BP's Rides;
- 2005 Kawasaki Ninja ZX6R- Mods: ECU Jumper, Akrapovic Slip-on, Power Commander III, 8000K HID's.
- 2K2 Maxima 6 Speed-Mods: Advanced Timing, Cattman Cat-back Exhaust, H&R Springs, Tokico Illumina Struts, Konig Theory 19" Rims.
Old 10-13-2005, 05:00 PM
street_racer_00's Avatar
street_racer_00 street_racer_00 is offline
Hell, I made my own WAI for about $10 total in materials ($3 for a 2' long piece of 3" diameter ABS pipe, $6.50 for a 3" to 2" flexible drain coupling to attatch the ABS to the TB, and .50 cents for the nuts and bolts to attach the K&N filter to the MAfS)...works just as effectively for like 1/10th of the price of buying one from injen...go home depot!
2000 Nissan Maxima SE, autotragic, sterling mist
My Max: Getting smoked by boosted cars since 2004
2004 AF award winner: longest time period w/o posting an actual street racing story
Originally Posted by CassiesMan
I got to see boobiues!
Old 10-14-2005, 02:40 AM
Re: Re: Warm Air Intake?
Originally Posted by street_racer_00
... 2" flexible drain coupling ...
My guess is that vibration kills the MAF resistors. Thereby the installation should be very flexible: attachement to chassis wia rubber bits, the air tube engine coupling - flexible.
As engine always makes sudden moves & vibrates, all attachement to the outer arc 'takes in all' vibrations causing MAF to vibrate. The 3gen VGE tube's MAF end sits near the center of this arc, and thus is mechanically positioned to near 'neutral' point (from engine movement). It may have longer life span b/c of that. (Otherwise, from airflow point of view, its the worst 'ever' fabricated...)
From this viewpoint, later Maxima engine models's MAF air tube coupling is suspect conduct to engine vibrations to MAF, and thus cannot be too flexible. There exists nowadays marvellous (silicone?) super flexible hosing possibilities in the raw materiel shops.
Old 10-16-2005, 12:06 AM
Ceasars Chariot Ceasars Chariot is offline
warpspeed y will be perfect, stick with stock unless you want a warm air intake like the injen. injen looks the best but if you have to have one go with frankencar imo.
97 Nissan Maxima (NA with USIM) - [email protected] mph
97 Nissan Pulsar SRV VZR (stock) - [email protected] mph
Old 10-16-2005, 07:44 PM
update...im goin with a budget y pipe and possible a frankencar intake if i have the loot.
Old 10-18-2005, 11:48 PM
sounds good, enjoy
Old 10-23-2005, 07:17 PM
SuperStock96 SuperStock96 is offline
Is there much difference between the Cold air intake and Warm air intake? I am up between the Cattman CAI with Monsterflow filter or the Berk intake (seems exactly like the frankencar) with the Apex'i filter. I like looks of the Berk better, but if there is much of a difference I'll go with the CAI. Anyone know about these?
Just a bit better than stock: Berk Intake w/ Apexi Filter, Cattman Y-pipe, FastCat, Cattman Catback Exhaust, TS ECU, Various Lighting Changes.
Old 10-24-2005, 02:51 PM
what do you think the performance gains will be.
if im at 190hp/205 now and run like 7.3-7.5 to 60mph...what will the gains be like for the frankencar and warpspeed y?
like 210hp/???tq and how quick to 60?
the power to weight seems to change considerably...any ideas would be awesome.
Old 10-24-2005, 06:57 PM
BP2K2Max's Avatar
if you figure you make about 175 whp stock, you'll probably see around 200 whp, mostly due to the y pipe.
if you look here: http://www.motorvate.ca/mvp.php/504
it shows gains as high as 30 hp in some areas on a stock 95 5 speed from just a y pipe, it gives an extra 15-20 ft-lbs of tq too. best bang for your buck you can get on a 4th gen. it's worth every penny.
BP's Rides;
Old 10-29-2005, 01:12 PM
ninos_maxima ninos_maxima is offline
Send a message via AIM to ninos_maxima
its not called a wai, its called a short ram
Old 10-30-2005, 08:02 PM
dfownz dfownz is offline
BP2K2Max can you post a pic of your DIY intake?
Thanks man,
DF
Old 10-30-2005, 11:31 PM
BP2K2Max's Avatar
actually, it was street racer 00 with the DIY intake. i had an intake on and due to MAFS problems i went back to the stock airbox.
BP's Rides;
