Old 10-12-2005, 06:36 AM
cc10is cc10is is offline
radio code
94 3000gt. i have the radio code, but it just says off cause my stupid brother thought it would be a good idea to just guess. so now it just says off. I unhooked the battery overnight, but it still says off, does anyone know how to get the codE screen back?
Old 10-12-2005, 08:45 AM
JordanVR4 JordanVR4 is offline
Send a message via AIM to JordanVR4 Send a message via MSN to JordanVR4
Re: radio code
i think you have to leave the key in the on position for like an hour
Old 10-12-2005, 09:45 AM
wont that kill my battery? is there any other way? man, u think they would make some easier way.
Old 10-12-2005, 10:59 AM
l_eclipse_l's Avatar
l_eclipse_l l_eclipse_l is offline
I'm pretty sure you have to disconnect the radio at the harness and reconnect it. The code screen should come on again.
'92 3000gt SL
Zoom Stage 1 Clutch
Originally Posted by kjewer1
I disagree. Better is better. Bigger is just bigger.
I just made that up, and I like it.
Old 10-12-2005, 11:41 AM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: radio code
NO
correct! put the key in the ignition, turn it to the ON position (but don't start your car), and leave it there for an hour. ohh, and make sure not to lock your keys in the car , that's what i did!
this is how you reset your radio so that you can enter the security code. this is what the guy at the dealership told me to do, and after doing this it worked.
good luck.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-12-2005, 05:22 PM
Ok sorry, worked for me when I did it on my car. Glad you corrected me though.
'92 3000gt SL
Zoom Stage 1 Clutch
Old 10-12-2005, 07:53 PM
Twizted_3KGT's Avatar
Twizted_3KGT Twizted_3KGT is offline
Re: radio code
you can turn the car on....its just a matter of time...doesn't have to be all at once...just have to drive around for an hour total, until it says code again.
1997 Mitsubishi 3000GT VR4 - 269AWHP/290AWTQ (Mustang Dyno) - [email protected] - 1.756 60ft. - [email protected] (Best TDO4-9B Time) - Driver Mod - IPS TD04-19TL - SPEC 4+ - Wiseco Pistons - 3SX Custom Forged Rods - PMP FMIC + Much More.
Old 10-13-2005, 10:36 AM
Mikelb's Avatar
Mikelb Mikelb is offline
Send a message via AIM to Mikelb
Re: radio code
yeah, the key has to be in though and the radio turned on for that clock to run down... had that problem working on a volkswagen
Originally Posted by Blackcrow64
I write a lot... I wrote one song about this chick I was messing with that was uhhh... Well, lets just say I called it "Forbidden Love"
1991 Eagle Talon TSI - Broken
Head removed, block broken, trans in hatch
1991 Eagle Talon TSI AWD- in pieces
3" exhaust, rebuilt bottom end
Project: Assemble the Eagle is underway... and now with AWD
2003 Lancer Evo 1630hp/1593ft lb tq
