| Engineering/ Technical Ask technical questions about cars. Do you know how a car engine works? |
87 teg d16a1, to a b18 gsr
The title pretty much says it all, i was just wondering if it can be done, and if so what are the specilty parts im gointo have to get.
Money=Power=RESPECT JDMPOWER
Re: 87 teg d16a1, to a b18 gsr
Post this in the integra forum. By the way, money does not equil power, and that does not lead to respect.
it can be done pretty easily. the b18 was used in the integra and should use all the same mounts so you'd just need to make sure the electronics, transmission and fuel systems are compatible. you should make sure though before you start because if they didn't use the same mounts (which is doubtful) you might have to buy or fabricate some. i would think the electronics and fuel systems should be compatible to make it easier, from a parts perspective, to make the car with the 2 different engines.
The mounts are not the same. Integras did not have b motors untill 90, the older ones used d motors. Mounts are easy to find, you will need to rewire for mpfi, you will need differnt hubs, and you will need the ecu. There are also other things you will need but this is the basics. Like I said, if you post this in the integra forum you will get alot better responce.
