Old 10-11-2005, 08:23 PM
knucklescw knucklescw is offline
Unhappy cooling fans
coming home from work today whenever i stopped steam would come from the front end. when i got home i popped the hood and it was steaming its ass off. i let cool off and started it up again and noticing that the fans were not coming on. is this a common problem with the 1993 3000gt? what should i check first? the thermostat, cooling temp sensor, relays? please help! i can't go a day without driving this car!!
it's my baby.
Old 10-12-2005, 01:21 PM
AutostradaVR4 AutostradaVR4 is offline
does your temp gauge work? what was it reading?
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-12-2005, 08:46 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: cooling fans
yes, what did you temperature gauge read?
you might check the thermostat. my 93 3000 base overheated once just randomly and turns out the thermostat had melted into one piece and wouldn't let coolant flow through the system. but as the 6G72 is a stout block, all i had to do was replace the thermostat.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-13-2005, 12:11 AM
deagle50ae deagle50ae is offline
Re: Re: cooling fans
same thing happend tome w/ 93 VR4. deffinitely check you thermostat. you cna test it by putting it in boiling water too see if it opens. it's a cheap and very quick fix (30 mins?) also, make sure you're coolant didnt just overflow from being too full, I've seen that happen too many times to count. let us know what's up. good luck.
-Josh
Old 10-14-2005, 02:47 AM
yeah it was the thermostat. the rubber gaskets were warped. thanks for the replys though!
