Go Back   Automotive Forums Car Chat > Oldsmobile > Aurora
Old 10-11-2005, 07:37 PM
Bidderboy Bidderboy is offline
Air Check Valve?
I've just bought a 01 Aurora with the 3.5 I've been getting the little things worked out that it has needed. I've replaced the Air Pump since the Check Engine Light was on. The new Pump was on for about a Month and it started to whine, so I took it off and exchanged it for another one. Now the new one seems to be getting a little loud. The tubes that go to the pump have moisture in them... I assume that is condensation from the exhaust since I haven't drove it in the rain.
Could it be that I have a bad Air Check Valve? How do I check them? I also notice a rough idle. I've taken the Throttle Body off and cleaned it, which it needed. I put new plugs in. I noticed a little oil in one of the plug holes. I also run a can of injection cleaner through it.
Thanks for any Help!
Old 10-12-2005, 11:19 AM
zephram22's Avatar
zephram22 zephram22 is offline
Send a message via AIM to zephram22 Send a message via Yahoo to zephram22
Re: Air Check Valve?
If I can get your email address, I'll send you all the data I can related to the air pump system in PDF format from ALLData. If you are interested, just Private Message me and I'll send it to you.
1963 Triumph TR3 12K
1995 Buick Century Special 178K
1999 Chevy Lumina LTZ 160K
2001 Suburu Forester 53K
2002 Oldsmobile Aurora 3.5 45K
2004 BMW Z8 3K
2005 Dodge Charger .5K
2006 Jaguar XJ12 1K
