Old 10-11-2005, 04:27 PM
Spazfishy Spazfishy is offline
Chevy Cav Brake light and blinkers don't work?
Hi I have a 2000 Chevy Cav 4 cylinder car. The problem that i am having is that my brake lights and blinkers no longer work. The running lights work fine.. I have already checked all the fuses and the light bulbs and there are no problems there.. What would be the recomended next step?
Thank you in advance..
Old 10-12-2005, 05:27 PM
quake61's Avatar
quake61 quake61 is offline
Re: Chevy Cav Brake light and blinkers don't work?
get an ohmeter or any other thing to check for voltage and trace the wires until u see voltage present
check for loose connectors and ground too
if fuses and bulbs r ok must be a loose ground or a loose connection between wires
