Old 10-11-2005, 03:10 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
tps?
alright, I'm flat on my face on this one.
victim is my 85 305 tpi.
problem is out of nowhere, driving along the engine began sputtering and the harder you pressed on the gas the more it fell on it's face.
immediately I thought it was a fuel problem. changed the filter and pressure tested and everything seemed to be in order. nope, as soon as put into gear same crap.
check the entire ignition system out, not the prettiest but I have seen worst, so average mid life on it. and spark is nice and blue, plugs and wires are not but 3 moths old, and none of the wires are burned either.
But the motor will start and then fall dead in a matter of seconds.
so i try the maf out as they are prone for this behavior. the first times, yes it would start, run like crap then eventually die. and run rich.
now if I disconnect the maf and tps it will idle all day long and not burn your eyes out of their sockets.
after this discovery, I found that there is a flat spot in the tps at about 3.3 volts in sweep.
dosen't throw any codes, and i would think the darn thing should still idle since the flat spot is at what 2/3 throttle, no?
if any body out there has had a similar issue with a tps behaving like this please say so, I've never seen this. I've always seen with a flat spot, the car will ilde unless the spot is at the low voltage, closed butterfly end. $59 is a bit of gamble right now, Car is getting tucked away for winter but i'm stumped here
Old 10-11-2005, 05:36 PM
FormulaLT1's Avatar
FormulaLT1 FormulaLT1 is offline
Fight the powwa!!!
Send a message via AIM to FormulaLT1 Send a message via MSN to FormulaLT1 Send a message via Yahoo to FormulaLT1
Re: tps?
You know the TPS is adjustable , right?
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart.
Mods: Weight reduction (I don't wear underwear)
Old 10-12-2005, 10:05 AM
wrightz28's Avatar
Re: tps?
Yes, and it is set at .54 volts closed and sweeps to 4.5v at WOT as should be.
Min. idle speed is correct as well as IAC function.
