Go Back   Automotive Forums Car Chat > GMC > Envoy
Old 10-11-2005, 01:31 PM
Tom1999d Tom1999d is offline
Unhappy interior fan switch failure
I have a 2002 Envoy with 96k - mostly trouble free miles.
I recently lost interior fan speeds 1 thru 4. 5&6 still work.
Any help?
Tom
Old 10-14-2005, 02:35 PM
maxwedge maxwedge is offline
A990 racer
Re: interior fan switch failure
easy fix replace blower resistor mounted on heater case behind glove box, 25.00 part.
Old 10-15-2005, 02:05 PM
Re: Re: interior fan switch failure
do you have the GM part number? Big help if you do.
Old 10-24-2005, 09:35 PM
Re: Re: Re: interior fan switch failure
OK I've been behind the glove box and I dont recogonze the resistor block right away. Is it on the right side, left side? Can you descrribe it.
Tom
Old 11-02-2005, 06:18 PM
I fixed it. 2 screws (7mm) to remove kick panel below the glove box, 2 screws to drop the resistor straight down (7/32"). Unplug and plug in the new one. GM part no 89018604 - for my 2002 SE. The fan works fine and!!! the AM static noise is all but gone! I have digital photos & directions if anyone wants them. Tom
Old 11-23-2005, 09:57 AM
gavin123 gavin123 is offline
Could you kindly forward the photos & directions for the project above.
Sounds like I have the same issue, [email protected]
Old 11-23-2005, 06:31 PM
03 lowered envoy 03 lowered envoy is offline
Blower Motor Resistor Assembly Replacement
Removal Procedure
Remove the right closeout/insulator panel. Refer to Closeout/Insulator Panel Replacement - Right in Interior Trim.
Disconnect the blower motor resistor electrical connector (3).
Remove the blower motor resistor mounting screws (2).
Remove the blower motor resistor (1).
Installation Procedure
Install the blower motor resistor (1).
Install the blower motor resistor mounting screws (2).
Tighten
Tighten the screws to 1.9 N·m (17 lb in).
Connect the blower motor resistor electrical connector (3).
Install the right closeout/insulator panel. Refer to Closeout/Insulator Panel Replacement - Right in Interior Trim.
Old 05-13-2006, 03:28 PM
Zingbat Zingbat is offline
It sounds like I have the same problem with my 03 Envoy. Can you send me the digital photos and instructions? [email protected]
Old 06-30-2006, 05:02 PM
ronin_anthony ronin_anthony is offline
There are two different resistors for the envoy. I've seen where some models with dual climate control use a resistor that costs $90.
Old 06-24-2015, 06:33 AM
Postman77 Postman77 is offline
Can you forward pics for me, [email protected]
