Old 10-11-2005, 01:05 PM
siu-p siu-p is offline
glue on Windows
I got glue on windows, what is the best way to remove it? I heard of sanding it and polish it? what's the right way to do it?
Thanks
Old 10-11-2005, 01:23 PM
freakray freakray is offline
AF Modelrater
Re: glue on Windows
Using a search feature usually works for me, it's always helped in the past.
AF User Guidelines
Old 10-11-2005, 01:34 PM
I've try using search but nothing come up.
Old 10-11-2005, 02:19 PM
Vric's Avatar
Vric Vric is offline
Re: glue on Windows
There is no way to get rid of glue on clear part (well sanding polishing can, but it will never look like before)
You are screwed...
Old 10-11-2005, 02:33 PM
Jaymes's Avatar
Jaymes Jaymes is offline
Re: glue on Windows
If you can sand it off you can get it to look 80% or even 90% back to original. Start with maybe 600 grit and work your way up to 2000 or higher if you can. Then use rubbing compound or plastic polish. Meguir's scratch X also works well. I've done this with sanding off the lines off a headlight and it looked 90% clear afterwards. You can also dip it in future floor polish to finish it.
Old 10-11-2005, 02:36 PM
carlisimo carlisimo is offline
Send a message via AIM to carlisimo
Re: glue on Windows
Jaymes's said it well. A lot of people have good luck using toothpaste as a last step - it's a mild abrasive and it gives you long-lasting freshness.
From now on, use white glue for clear parts. Easier to take off, and you'll never have fogging problems.
Old 10-11-2005, 05:23 PM
Re: glue on Windows
thanks for the help guys!!!
Old 09-13-2007, 01:55 AM
SeanyG's Avatar
SeanyG SeanyG is offline
Re: glue on Windows
I know this is a very old thread but it is one of those things that I have always wondered...
What glue is best to use when attaching clear parts such as windscreens, headlights etc? I have heard a few say 'white glue', do you mean PVA Wood glue? Any brand names would help me out here.
cheers guys
Sean
_______________________________
http://www.scalereproductions.co.uk
WIP: Ferrari F40
Old 09-13-2007, 02:07 AM
cyberkid's Avatar
cyberkid cyberkid is offline
Re: glue on Windows
cheers guys
This has been asked quite a few times...
I personally use Tamiya's Craft bond and Micro Scale's Kristal Klear.
Both are white glue...
I'ts more or less the arts and crafts glue you use. Elmers is a common brand.
Searchh a little and you will find that this has been asked and answered a few times
http://www.automotiveforums.com/vbul...archid=2002035
Please read the following linked articals before posting a question.
Once you have and still have questions, try to post your questions clearly.
This will make a lot of people's blood pressure drop back to normal, including mine.
NEW TO THE AF MODELLING FORUM? PLEASE READ THIS FIRST
AF Car Modeling Tutorial, How-To and Product Review Depository
AF Car Modeling Frequently Asked Questions [FAQ] - * Look here first! * ver2.0
And finally,I wish you all happy modeling
Old 09-13-2007, 02:42 AM
AllAlone.Gz's Avatar
AllAlone.Gz AllAlone.Gz is offline
Re: glue on Windows
I use that testors clear part cement and window maker, to glue my clear parts. It's also handy for when a clear part gets messed up.
'99 Honda Civic Hatchback-R.I.P May 04, 2010
NikonEquipped.
Flickr.com/photos/oneohnine27
OneOhNine27*
