Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 10-11-2005, 12:45 PM
'RayMan 'RayMan is offline
Oil Light
I've got a 97 3400 Transport and the oil light is flickering when idling @ normal temp. The motor seems to be loping @ idle as well. Any hints to what is wrong?
It is not how fast you drive, but how you drive fast.
Old 10-11-2005, 01:10 PM
cdru's Avatar
cdru cdru is offline
Re: Oil Light
Oil light means low pressure. The oil pump is driven directly off of the cam shaft so a low idle speed could drop the oil pressure dangerously low. It also could be a faulty oil pump, failed pressure relief valve at the pump stuck open, or a faulty oil pressure sensor.
Vinyl adds horsepower, right?
Old 10-11-2005, 01:47 PM
those were my thoughts too, but what about the motor loping at idle?
Old 10-11-2005, 02:54 PM
cdru's Avatar
Re: Oil Light
Donno on that. Could be one of many different things. Failing coil, faulty plug or wire, stuck EGR, low fuel pressure or clogged injector, MAP/MAF sensor failing, vacuum hose unhooked/has a hole, etc...
Old 10-11-2005, 03:06 PM
Re: Re: Oil Light
Just replaced coil, plugs, wires, egr, fuel pump, pressure regulator, rails, injectors. Tested and OKed MAP/MAF sensor.
Also there is this very noticable click about very 3-4 sec sounds like its coming from Cyl. 6. I have checked the knock sensor and seems to be functional. There was no abnormal wear on the plug when changed.
Old 10-11-2005, 03:24 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Oil Light
Have you done a compression test? You may have a cylinder going bad causing both the low oil pressure and the loping at idle.
Old 10-11-2005, 03:43 PM
have not, planning doing that this weekend.
Old 10-11-2005, 03:44 PM
richtazz's Avatar
Re: Oil Light
let us know what you find out.
Old 10-11-2005, 03:48 PM
anyone in the memphis, tn mind giving me a hand?
Old 10-13-2005, 05:11 PM
well if i find out i have to do a tear down. i think i may try to swap it for a L48 out of 75 vette thats been bored,stroked, and ported w/ 750 holley double pumper and chevy hei distributor. i like the sound of 375 hp and 328 ft/lbs in that little beast
