Old 10-11-2005, 12:42 PM
goalkprrr goalkprrr is offline
Angry headlights shut off
97 blazer turn on lights. Every once in a while just the headlights click off for a few seconds then come back on. Dash lights and running lights stay on just the front headlights will go off and on. Has happened a few times dealer has no idea they say they checked switch and seems to be fine. Need to tear into farther to try to figure out$$$$$$$$
Old 10-11-2005, 01:47 PM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Pull and clean your headlight grounds on the rad support... More than likely they're dirty/rusty and not connecting 100%
Old 10-11-2005, 05:37 PM
Re: headlights shut off
Where is the rad support located for that??
Thanks
Old 10-11-2005, 05:55 PM
rlith's Avatar
It's the entire portion of the front of your truck that holds the radiator in place and supports the side body of the truck (fenders, etc) You will see a black wire on either side coming from the harness screwed/bolted into the support.
Old 10-12-2005, 09:12 AM
Samsul Samsul is offline
have you changed the light bulbs recently?
it is a switch, where the thermo-fuse is
