Old 10-11-2005, 09:33 AM
kfnpemai kfnpemai is offline
Air bag warning light
98 F-150
Air bag light is flashing 52 code. Any one know what this means? Also cruise control not working. It's been raining alot. Is there anyway to reset code to see if it triggers again?
Thanks
Old 10-11-2005, 09:04 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Air bag warning light
You are getting low voltage or no voltage on connecter C-209
Terminal 14 red/white wire from fuse 2 10 amp in the under hood distribution box.
Check voltage on both sides of that fuse first.
You will need a air bag capable scanner to clear code.
and the scanner may read out the voltage to.
But unless you are trained in SIR/airbag repair it is best to let someone that is fix them. Them suckers can injure or kill you in a split second.
MT-2500
Old 10-17-2005, 01:02 PM
Eddie05Wrangler Eddie05Wrangler is offline
I had that in my 94 F150. It was the "clock Spring" in the steering column - (described as sort of a CV joint for elect. contacts).. Ford dealer said it was common. Not too $$ to fix. I had them do it, did not want a face full of airbag
