Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 10-11-2005, 09:16 AM
Blylock Blylock is offline
4wd front axles unlocking**UPDATED**
My front axles unlock and grind, usually when going from forward to reverse, or under load in 4wd, hi or low. anyone else come across this problem, and what steps can i take to fix it?
1998 Ram 1500 SLT 4x4
5.9L
Dynomax Performance Dual Exhaust
KN cold air intake
Bosch +4 Platnum Plugs
180 Degree Thermostat
I would suggest to anyone with a Ram to convert to a performance exhaust, especially if towing alot.
Old 10-11-2005, 11:26 AM
foreperson foreperson is offline
Had the same problem with my truck. the trouble was the vacume lines on the front axle which had leaks which caused the truck to engage but when strain came on it would would disengage because it was not getting the right amount of vacume. Fixed lines and it works perfect.
Old 10-11-2005, 02:33 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 4wd front axles unlocking
My thought, also.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-13-2005, 07:19 AM
After further inspection, its my transfer case, not my axles. its not fully engaging. Ive adjusted the shifter to make sure its going in all the way, but it still hangs sometimes. Sometimes it locks in, but usually it pops back out. Is it hosed, or is there something i might be missing?
5.9L
KN cold air intake
Old 10-13-2005, 07:25 AM
If you're able to move the shifter as far as the transfer case will allow, then the problem is going to be internal. If this is the case it sounds like some of the engagements inside may be worn, and when you hit the right (or rather wrong) combination inside it slips out; if you hit the better (less worn) then it stays engaged.
Old 10-29-2005, 05:42 AM
I had my xfer case rebuilt. The shift forks were worn out, and the drive chain sloppy. cost me 400 bucks, but well worth the working 4X4, especially here in upstate NY, where we get feet of snow at a time.
5.9L
KN cold air intake
