Go Back   Automotive Forums Car Chat > Nissan > Altima
Old 10-11-2005, 09:09 AM
tomchu tomchu is offline
front o2 sensor (o2 sensor on header) STUCK
for the life of me, i cannot pull this sucker out
any tips/advice/help?
thanks
Old 10-11-2005, 09:54 PM
JustSayGo JustSayGo is offline
Send a message via AIM to JustSayGo Send a message via Skype™ to JustSayGo
Re: front o2 sensor (o2 sensor on header) STUCK
Buy PB catalyst penetrating oil and spray some on the threads. AutoZone, most auto parts stores, maybe even Walmart have it. It dissolves rust. WD-40 is good starting fluid, smells nice but does very little to loosen parts. AutoZone has the correct socket for O2 sensors to loan you. If it is still stuck you will have to heat a spot on header to expand the threaded area that the sensor screws into. If you are working with stainless steel, it takes a lot more heat because the heat will spreads and cools so quickly. If the socket is slipping use vise-grips that say Vise-Grip on them rather than Made in Taiwan.
Old 10-11-2005, 11:03 PM
i used a 7/8 o2 sensor remover
is that ok?
i think i just need the penetrating oil, if what i used is right
please confirm so i can go out and buy some
thanks!
Old 10-12-2005, 12:46 AM
If the socket doesn't slip that is fine. You have the correct tool with a slot for the wires. Cut the wires off if they are in the way and you will be using a new sensor. The label on the can is yellow and brown.
