Go Back   Automotive Forums Car Chat > Dodge > Intrepid
Old 10-11-2005, 02:26 AM
jimh jimh is offline
Question Drive axle removal
My Haynes book says that the half-shafts should just pull out from the stub shaft. If it "hangs up on the snap ring, place a large prybar between the CV joint housing and the transaxle housing and pry the housing out". Well, I tried this and it does not budge. Is there some trick I don't know about?
Thanks in advance!
Jim
Old 10-11-2005, 02:37 PM
theFREAKnasty82's Avatar
theFREAKnasty82 theFREAKnasty82 is offline
Re: Drive axle removal
sometimes, you have to move the snap ring around just to free it. Try moving it around with a screwdriver and pry it out with your bare hands. That's how I've been able to free stuck CVs.
Daily Overhauls Do Get Expensive
Dangerous On Days Gears Engage
Dead On Day Guarantee Expires
Dead Or Dying Gas Eater
Department Of Defense Garbage Equipment
Dodge Owners Don't Get Excited
Don't Overdrive Gutless Engine
Drips Oil Drops Grease Everywhere
1995 Dodge Dakota SLT 3.9 V6
1995 Jeep Grand Cherokee Laredo 5.2 V8 4X4
Old 10-11-2005, 03:03 PM
Thank very much. I will give that a try. I'll post the results, good/bad. Thanks again,
Jim H
Old 10-13-2005, 06:42 PM
wafrederick wafrederick is offline
Banned
There is another way,use a long punch by hitting the punch with a BFH on the end of the axle.The wheel bearing side is another story,it may be stuck in the wheel bearing and will not come out sometimes.I have encountered this a lot of times,a common problem.
