Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-11-2005, 01:11 AM
griddle griddle is offline
Unhappy HELP!Coolant light problems....
Hey everyone. Okay, here's my problem. The coolant light on my 95 rs will not stop coming on. My coolant is up to level, the thermostat has been changed, the fluid has been flushed and changed and the water pump is just a little over a year old....
This sounds crazy but when I go around a long curve the light goes off and then comes back on.
Anyone got any ideas on what's up? Sensor maybe?
Thanks!!!!
Old 10-11-2005, 07:31 AM
spyderturbo007's Avatar
spyderturbo007 spyderturbo007 is offline
Re: HELP!Coolant light problems....
I would bank on the sensor. It also sounds like it could be a connection problem. You might want to check out the wiring.
1997 Spyder GS-T
5-Speed
EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads
Old 10-11-2005, 08:56 AM
-Josh-'s Avatar
-Josh- -Josh- is offline
Automotive love doctor
Send a message via AIM to -Josh-
ECT sensor most likely as spyder said, i dont think it's that expensive.
Self improvement is masturbation
AF User Guidelines
What is a mippie? - click
Old 10-11-2005, 11:47 AM
The ect sensor has been replaced and the light is still coming on. Is there a sensor at the bottom of the reservoir tank or is that just in the turbo engines?
Old 10-11-2005, 12:37 PM
Okay so when I went out and started my car a few minutes ago a screeching noise happened. It quickly stopped and when I drove it around the block a faint whirring noise was coming from the engine. The starter and the alternator are fine.....please don't tell me it's the freaking water pump again
