Old 10-10-2005, 11:15 PM
rbsteve rbsteve is offline
Oil Pan Gasket
Ive searched through the forums here and found conflicting answers. My oil pan is leaking from the gasket and i was wondering how to remove the pan to get at it. Two sides are open so not a problem. One side is covered by the driveplate inspection cover which is easily removed. Its jsut that one last side, which seem to have the bolts located directly above part of the chassis.
How can i get to that last side of bolts ?
Ive read about people renting engine lifts and such, and repairs of 1400$ +. My Haynes repair manual isnt very clear either.
Thanks in advance
Steve
Old 10-11-2005, 05:56 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: Oil Pan Gasket
Sorry Steve but unfortunately, the pan on the 3.8 is very hard to drop and you will need to lift the engine far enough out of the car to be able to remove it. That is why you have seen repair bills to $1400. An engine hoist will become your best friend before this job is over.
Old 10-11-2005, 10:14 AM
UGH !
hmmmm so i guess jacking it up from underneath wont cut it...tighten the bolts it is !
one more thing, what is this "windage tray" ive seen talked about ?
THX GTP Dad
-Steve
Old 10-11-2005, 10:20 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Oil Pan Gasket
The windage tray is a plastic baffle built into the gasket to keep the oil from sloshing around and getting into the crankshaft as it spins.
Old 10-11-2005, 07:41 PM
regalfriend regalfriend is offline
Re: Oil Pan Gasket
My oil pan gasket was replaced on a 1997 Regal GS...i think its similar...instaed of lifting the motor they dropped the sub frame....i guess labor wise it's probobly about the same time...a pretty big job.
