Old 10-10-2005, 10:01 PM
bluebuick91 bluebuick91 is offline
front end noise
after finding the viberation on the front passengers side and fixing it,the car still drives good, the front end seems ok but i noticed that when i am sitting at a stop light and i go to take off i here a noise from the front end on the passenger side almost like a clunk not all the time and it does not clunk when i turn the wheels just on take off somtimes, so does that meen that the CV joint is bad, thank you all for helping me
jennifer
Old 10-11-2005, 05:24 AM
GTP Dad GTP Dad is offline
Pontiac Guy
Re: front end noise
Not necessarily, the problem could be with the upper strut mount, dry bushing or a sticking brake. I would have someone check the CV joint to make sure that it is not loose and I would also have the brake and strut checked. You can lubricate the rubber bushings by spraying a good quality silicone lubricant on them. If one is dry that should correct the issue.
Finally, you may want to have the upper and lower control arm bushings checked to make sure one has not gone bad. You can do this but you may want to have a mechanic or alignment shop check it for you. Good Luck!
