Go Back   Automotive Forums Car Chat > Ford > Contour
Old 10-10-2005, 09:53 PM
muffa muffa is offline
Angry 95 Ford Contour Stalling
hi I have a 1995 Ford Contour and I am at my end with it. My nephew is a mechanic at Mercedes and has tried to change the things that could be the cause but to no avail. maybe someone has had this problem in the past. It all started with a bad alternator we replaced that new battery to . The car is shaking at idle and in gear and stalls if no gas is given coming to a stop reversing and switching into gears. We have changed the following. Valve gasket cause oil was getting to spark plugs, plugs, wires, timeing belt, fuel filter, fuel pump, o2 sensor, pcv,air filter, and a few others but still nothing keeps happening any suggestions.
thanks
Old 10-10-2005, 11:02 PM
beyondloadedSE's Avatar
beyondloadedSE beyondloadedSE is offline
AF Ford Contour-Advisor
engine type, trans type would be helpful. thanks.
"The CEG Nazi"
www.contour.org
1996 Ford Contour SE - Sold
3.0L V6 and Arizona Dyno Chip Turbo Kit
364 whp, 410 wtq @ 16 psi and only 4,700 rpms.
1999 Tropic Green SVT Contour - Bone stock and MINT
Old 10-15-2005, 01:59 AM
Re: 95 Ford Contour Stalling
hi sorry
it is a 6cy duratech i think automatic trans.
thanks again
Old 10-30-2005, 09:42 PM
phil-l phil-l is offline
Try cleaning or replacing the IAC (Idle Air Control) valve. It's a common cause of idle problems on the Duratec.
