Old 10-10-2005, 07:04 PM
Bluntablo Bluntablo is offline
92 Jeep Starting Issue
Ok, Im not very savy in my tech/mechanical skills, but here is my Delima...
My starter is less than a year old as is my battery...I have a 92 Jeep Cherokee, and I get nothing when I turn the key...the radio and All has power, but the Starter does nothing...now, I replaced the Starter 4-5 time in the past 2 years ( lifetime warranty luckily)...but, I sitll ahve this problem...I could roc the Jeep, or turn the key too on and put it in Neutral and it would start, but that has ceased working...now it wont start at all....
What could thi possibly be...the Neutral Safety switch maybe?...or A much larger electrical problem...It runs great s I keep up with the maintenance...but this really sucks...Im am clueless too the problem area...
any suggestions?
thansk
Old 10-16-2005, 12:21 PM
simpleman1776 simpleman1776 is offline
Re: 92 Jeep Starting Issue
any suggestions?
thansk
sounds like a blown fusable link in the power to solenoid wire
Old 10-16-2005, 11:15 PM
Saudade's Avatar
Saudade Saudade is offline
If putting it into neutral worked for a while, I'd suspect the NSS too.
Check out: http://www.jeepin.com/features/nss/index.asp
Old 10-17-2005, 09:31 AM
Re: Re: 92 Jeep Starting Issue
after reading hundreds of posts, I would say it's the NSS also.
Old 11-03-2005, 03:32 PM
troubleamakekid troubleamakekid is offline
I have the same Neutral safety switch problem for my 1993 jeep. Last time a buddy of mine fooled around w/ it in park and it turned on. My question to you is, i have tried millions of times ot get it to work in park and i have failed. Is there a certain way to giggle it in park. Thanks.
Old 11-03-2005, 07:36 PM
Saudade's Avatar
Until you can repair or replace it, try putting it into neutral.
