Old 10-10-2005, 05:13 PM
maxassassin's Avatar
maxassassin maxassassin is offline
Send a message via AIM to maxassassin Send a message via MSN to maxassassin
Question what dizzy do i need
ok so im still looking for the mpfi conversion stuff blah blah blah. well i foudn a 6th gen intake mani wiht wire harness from a y8 motor. would i need to use a obd2 dizzy or can i get away with soemthign else. as well what ecu would i use.
06 cbr 600 f4i
91 civic hatchback.
96 nissan pathfinder
Old 10-10-2005, 06:18 PM
slipknotcraig133 slipknotcraig133 is offline
Send a message via AIM to slipknotcraig133
Re: what dizzy do i need
are you going to go obd0 or what. If your going to go obd0 you need a dizzy off of a d16a6 si motor.
Got the car 1400
Need an H22a4 4000
Some Goodies to go Along With it 2000
Some Drag Slicks 750
Going to the Strip and Make V8's Say D*** Hondas PRICELESS
Old 10-10-2005, 11:26 PM
well i foudn a manifold and wire harness but its from a 6th gen honda which were obd2 so im wondering if i need do that. becuase the mani and wire harness are like 85
06 cbr 600 f4i
91 civic hatchback.
Old 10-11-2005, 01:50 AM
03TRDTacoma's Avatar
03TRDTacoma 03TRDTacoma is offline
you can use any OBD0 dizzy. trust me.
2004 Toyota Tacoma 4x4
1990 Eagle Talon TSi AWD
2002 Suzuki GSX-R 600
Old 10-12-2005, 08:29 AM
civic_boy91's Avatar
civic_boy91 civic_boy91 is offline
Send a message via AIM to civic_boy91 Send a message via Yahoo to civic_boy91
the obd dizzy wont bolt right up...you might have to open up the bolt holes so you can blot it on...that should be the only problem. its just the offset...
_________________________________http://VelocityFactor.com________________________________
1990 si hatch
b20b si tranny
megan race header 2.5 custom exhaust
50 shot
integra da rear disk (w/ 4040 valve)
powerslot rotors and barded lines all around
1994 Dx hatch
stock
Old 10-13-2005, 04:11 AM
civickiller civickiller is offline
Send a message via AIM to civickiller
if your just swapping intake manifolds, which has nothing to do with the distributor. the distributor is on the head not the intake manifold so if you want to stay obd0 use a si distributor. you wont even need any plugs from that y8 harness unless your going with vtec. wait you will need the obd2 injector plugs if you are using obd2 injectors. every other stock sensor on your motor plugs right up. might have to extend tps and iacv and map but youll see how it goes.
so just do the regular mpfi swap
Team Lonely Drivers
