Okay Guys My Battery Is Fine As Well As The Alternator And The Starter. When I Try To Start My Car It Wont Start The Key Turns Over And The All The Lights And The Radio Work But Doesnt Even Try To Start Nothing. I Replaced My Ignition Starter Switch I Replaced My Distributor And And Spark Plugs I Also Replaced My Fuel Pump And The Fuel Pressure Is Fine The Computer Of The Car Is Fine What Else Could It Be Anyone Have Any Ideas Tell Me Please.
Re: 1992 Camaro Wont Start Need Help
Maybe I overlooked something but do you have an alarm? When mine didn't start all the lights and parts were fine it turned out to be the Vehicle Anti Theft System (VATS). There was a little red light blinking under my dash signaling that a little plastic key came loose, so my car thought I was trying to steal it. Just a guess though, good luck...
Re: Re: 1992 Camaro Wont Start Need Help
We replaced the starter/selinoid, and still nothing. We are clueless, any ideas? |
When someone turns the key to start you need verify if there is battery voltag on the S terminal of the starter (usually purple wire). If not then the starters not getting the command to begin the show by either bad ign switch, or anti theft saying
theif.
If the car wont start, and there is a chip in the ignition key (you have a VATS system) try this test.
Put the key in the on position, pop the hood, use a screwdriver to connect the posts on the starter (you should see a spark) hold the driver there till the car starts and be careful not to get zapped. If doing this starts the car when turning the key did not, then the chip on your key isnt being read properly and its time to by-pass the vats system. I got my by-pass at www.ecklerscamaro.com, comes with easy installation instructions, only takes a couple minutes to put in and is only 29.99 plus shipping... so thirty-semodd-bucks and the problem is gone. Also, one more good reason to buypass the VATS system is that if you need to make more keys, you dont need to get the ones with the chips, you can buy regular keys. |
