Old 10-10-2005, 04:54 PM
sLADe781 sLADe781 is offline
Strut mount part number
Does anyone know what the strut mount part number is? It's for a '94 SL ECS equipped GT. I need the front and the rear part number. Thanks in advance.
Old 10-10-2005, 08:48 PM
Linebckr49's Avatar
Linebckr49 Linebckr49 is offline
Send a message via AIM to Linebckr49
Re: Strut mount part number
could you be a bit more specific as to what the mount looks like? does it look like anything in this picture?
NOTE: these are not part numbers. tell me which is the mount (i'm guessing number 40025B?) and i can find the corresponding part number.
93 3000GT base
K&N | long tube headers | 3sx crank pulley| testpipe | Addco front/rear sway bars (3SX) | rear strut bar & front 3-point strut bar (by JonVr4 on 3Si) | solid motor mounts | LSD insert | KYB GR-2 struts | intrax springs | adj. control arms | ss brake lines | 16% taller 5th gear (teamrip.com) | H4 conversion | push-button start | datalogger | HKS S-AFR | PLX WB O2
coming soon: adj. cam gears | bi-xenon HID retrofit
Old 10-10-2005, 11:38 PM
2Devious 2Devious is offline
http://www.3sxperformance.com/suspension-vertical.asp
bottom of the page has the mounts.
*edit* sorry, no PN. thought this might help tho.
1998 Mitsubishi 3000GT SL - Pearl White
Ralliart Filter | Bomz Intake Body | 3SX Lightened Crank Pulley | 3SX Polished Spark Plug Cover | Blue silicone hoses | Polished plenum | Painted / detailed valve cover | De Corsa Fusion Black 18x8.5 wheels | White/Blue Glow gauge faces |Pioneer DEH-P770MP Head Unit | Lilliput 7" motorized touchscreen | Audiobahn 6x9s | Audiobahn 5.25s | Audiobahn ATB10AT Sub | Stinger Digital 1.2 Farad Cap | AMD XP 2100+ CPU | 1G Ram | 60G HD | SBLive! | Nvidia GeForce
Old 10-11-2005, 09:22 AM
Yeah, Linebckr49, I think that the 40025B part is the strut mount (at least it looks like the ones on 3sx).
Old 10-11-2005, 02:47 PM
Musashi3000GT's Avatar
Musashi3000GT Musashi3000GT is offline
dealer said the front are mb949423 and the rear are mb338610.
06 GTO: SLP Longtubes, SLP Loudmouth II K&N intake,
Ported Intake Manifold,
Ported Throttle body, MAF screen delete.
Tunned by Jeremy Formato. 381whp, 376wtq.
07 Ion Redline: Bone stock w/ factory Competition package.
In response to a race my wife had while pregnant with our baby:
Originally Posted by jeepgclwj
Prediction.... I bet we will hear about a guy down in Miami thats the King of street racing in about 18 years...Way to get him started....
Old 10-11-2005, 06:28 PM
Musashi, are those strut mounts ECS or non-ECS?
Old 10-11-2005, 08:09 PM
none ECS. but you know, looking at that diagram it looks like the strut top would be the same for both. I mean it has no mechanical function at all.
Does the ECS on the SL affect the springs or the shocks? cause if it only stiffens up the shock then the strut top would deffenetly be the same. the strut top only supports the spring in place and if the srings on the SL are the same diameter as the base (and they are) then the only difference between ECS and non ECS would be the shock absorber and the little harness on the top of the diagram.
Old 10-11-2005, 08:14 PM
Well, 3sx has both ECS and non-ECS listed so I just assumed that they'd be different. ;o/
Old 10-11-2005, 11:08 PM
http://www.mitsubishi-parts-dealer.com/parts.htm
can try there...I'm too lazy to do it....just got outta work =P
Old 10-12-2005, 10:40 PM
That's awesome 2Devious....is there anyway we could get the part numbers from the pictures? I'm assuming that as far as the strut mounts for the front goes, it's the same for all since there was only one for FWD!?!
Old 10-13-2005, 12:31 PM
Linebckr49's Avatar
Re: Re: Strut mount part number
it looks like the front strut mount are the same for FWD ECS and FWD noECS. here are my search results from the website 2Devious posted (http://www.mitsubishi-parts-dealer.com/parts.htm)
search for 91-94 vehicles
strut mount, 3000 GT - 2WD 91-94 $57.40 $0.00 $48.79
Front suspension - Suspension components - strut mount
strut mount, 3000 GT - AWD 91-94 $57.40 $0.00 $48.79
strut mount, 3000 GT, w/o ESC - 2WD 91-94 $23.22 $0.00 $19.74
Rear suspension - Suspension components - strut mount
strut mount, 3000 GT, w/ESC - 2WD 91-94 $62.73 $0.00 $53.32
strut mount, 3000 GT - AWD 91-94 $62.73 $0.00 $53.32
i did the same search for 95-99 cars, and concluded the same thing: FRONT strut mount for the FWD cars are same, regardless of ECS or noECS. however, it appears that the REAR strut mount for FWD cars is specific for ECS vehicles.
[search for 95-99 vehicles]:
strut mount, 3000 GT - 2WD 95-99 $57.40 $0.00 $48.79
strut mount, 3000 GT - AWD 95-99 $57.40 $0.00 $48.79
strut mount, 3000 GT, w/o ESC - 2WD 95-99 $23.22 $0.00 $19.74
strut mount, 3000 GT, w/ESC - 2WD 1995 $62.73 $0.00 $53.32
strut mount, 3000 GT, w/o Power Sunroof - AWD 1995 $62.73 $0.00 $53.32
strut mount, 3000 GT, w/Power Sunroof - AWD 1995 $23.22 $0.00 $19.74
93 3000GT base
Old 10-13-2005, 05:20 PM
So Linebckr49, were you able to get the part numbers from the link 2Devious gave for an ECS?
Old 10-14-2005, 12:39 AM
Linebckr49's Avatar
sLADe, what model, year is your car?
i have two part numbers for the FRONT strut mount on the FWD cars:
for models up to 93.5: P/N MB633378 & MB949423
for all other models: P/N is just MB949423
i was not able to find any part numbers for the REAR strut mounts. actually, the program i have is the WinCAPS Mitsubishi Parts Search, so i think its pretty comprehensive and accurate. But considering the results i got from my previous search on the website 2Devious posted (my previous post), i think there are actually 3 part numbers that are relevant here. evidence for this are the three different prices for the 2WD strut mounts for Front and Rear (inclusive): $57.40 (front), $23.22 (rear no ECS) & $62.73 (rear ECS).
so given this information, and the part numbers i've provided, i think you're next step is to call the dealership and just ask them for the part number for your specific application. if they ask for your VIN, then just say no, you just want the part numbers. don't take their bullcrap, but they're usually nice to people who throw out part numbers b/c they think that you know a thing or two about cars :
93 3000GT base
Old 10-14-2005, 09:30 AM
I have a '94 SL with ECS. Yeah, I actually went to the dealership and when I asked them for it, they were asking me what the strut mount was. So basically after that, I just don't trust their judgement anymore! But hmm....if they have my VIN though, then they should be able to pull the right p/n for my car, right?
Old 10-14-2005, 01:40 PM
Linebckr49's Avatar
yes, if they have your VIN, they can pull the correct p/n for your car. and if you give them the part numbers i provided above, then they should be able to get an idea of what the strut mount is. most likely the parts numbers above are for strut mount on other years, but it MIGHT actually be the one for you car. just call and ask, and give them part numbers.
93 3000GT base
