| Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines. |
hello all,
I`m new to this forum and I hope someone can help with an ongoing problem I am having with my wifes car. When we bought the car I did the regular tune up on it. The car did not run too bad, but idled a little rough. I changed the plugs(nkg), fuel filter, wires, cap and rotor. The car got worse. ( the car would not idle properly when started up and when driving on the road at about 1500 rpm it would loss power). I would have to pull over and let the rpm`s come back up. I took it to my machanic friend and he could not find a problem with it, but he thought it could be the fuel pump. I changed the fuel pump but there was no difference. I installed a pressure guage and the pump is right on specs, but if you clamp off the return line the runs great. Up until this friday when it started doing the same things. Well I went out and replaced eveything again this weekend. Checked the voltage at the maf sensor and it is reading the same as the battery. Cleaned up all connnectors and grounds. The car starts good, idles down to about 850, then the rpms jump a couple hundred then come back down. When you go to drive the car it sputters and spitts and the idle drops to 5-600 and wants to stall. Is there anything else i can check before changing out the maf sensor? I have read a few other posts and this seems to be the solution that keeps coming up. This is a great forum and Thank you in advance for any help. ivan. |
Re: 90 maxima maf ?
Seems the IACV sticks, needs to be cleaned after 60-100k. see http://www.cardomain.com/ride/748507/4 "Is there anything else i can check before" Yes, checkit first: http://www.cardomain.com/ride/748507/9 I dont think its MAF: thats what stealers$hip will do if u let them. The reason is price: they buy it at 50$ and force-sell it to unawares with 750$. And btw. Pays to clic my CD site Favorite Links at left. .
. Maxima INFO pages was deliberately trashed (!?) by Cardomain; dont goto http://www.cardomain.com/ride/748507 ![]() There was a special Car Electronics -page http://www.cardomain.com/ride/748507/14 |
Re: 90 maxima maf ?
Hey Nahk, you wouldn't happened to have done a IACV write-up on the 5th gen max, would ya?
2000 Nissan Maxima SE, autotragic, sterling mist My Max: Getting smoked by boosted cars since 2004 2004 AF award winner: longest time period w/o posting an actual street racing story Quote:
Re: Re: 90 maxima maf ?
![]() Actually I need 3 of them. Two to sell, and pay the gvmt levied taxes on the donation... Socialismus WonderLand. Try Substitute Manual at: http://www.phatg20.net/ With 94 & 02 -manuals u may find what u need... BTW. To the MAF issue: if disconnected (3gen), causes idle roam... . |
Thanks again, Ivan. |
Re: Re: Re: 90 maxima maf ?
...Then this was a nice day!
Here is an update on the car.
Did the lacquer to the cap and changed the plugs.(old plugs looked good and tested ok) Waiting for new wires. Now this is where it gets interesting,started up the car and it ran real smooth with not a miss. Took it out for a quick ride down to the river and everything was great. Went back home, the car sat for 3 hours before I had to pick up the wife. Started the car and nothing but low rpm`s, sputtering and hesitating. Shut it off and immediately restarted it and it ran perfect. Tried it a few more times and the same thing. One time it would run good, the next bad. Any suggestions for this one? I might take apart the throttle body tomorrow, and clean that up. It probably is as dirty as the iacv was. Ivan |
Re: 90 maxima maf ?
A/T uses TPS: typically A/T is also problematic when TPS is faulty. (you have not complained that - or maybe M/T?) My bet is faulty MAF. They say its 50$ from junkyard... . |
Re: 90 maxima maf ?
Thanks for the quick reply Nahkapohjola, will start at it again. Will let you know.
Ivan |
If the current problem is only cold, points to MAF, TPS. If the current problem is only warm, points to MAF, O2. If the current problem is warm&cold, that seems to drop out O2&TPS. Which (O2-or-TPS) ECU uses, depends on cue from temp sensor - which may also drop out intermittently; p.8. What is Temp gauge showing?? ![]() (Cam pos sensor seldom depends on temp.) Have u got A/T Automatic tranny or Manual M/T??? . Last edited by Nahkapohjola; 10-12-2005 at 03:40 PM. |
Re: 90 maxima maf ?
Hello again, just got in from the car and found your new post. The car is an a/t. I just finished replacing the fluid and adjusting the shift linkage. The max starts to act up when hot and cold, more so when you take it for a drive. Run real good then the rpm`s drop off and there is no power at the pedal. The rpm`s drop to about 500 and then slowly come back up, even then it`s hit or miss if it will move.
I have found that there is a wire problem on the left side wires running to the iacv, if you give them a pull the engine surges. I have just removed the wrap to trouble shot any loose or broken wires. I off to pick up the wife. Thanks again Ivan. |
Long shot is alt charge voltage generated spikes: easy tst is to disconnect alt by taking connector off, see page 5. . |
Hello again, it`s been a long week and weekend.
This is what has been done to the maxima since last post. 1- maf sensor changed. 2- changed wires. 3- repaired break in wiring harness. 4- cleaned and regreased all connectors. 5- traced all grounds, cleaned and regreased, added extra grounds to alternator and distributor, missing o2 ground at exhaust. (added). 6- tested and reset TPS. 7- melted hole and cleaned out TPS, added missing o-ring.(reset) 8- added boost to gas just incase. Took car for drive after each repair, and it seems car ran a little better each time but the adle problem is still there. When car is warmed up in park it idles at approx. 850. When in drive and reverse 700. When you go from reverse to neutral 850, when you shift from drive to neutral it will rev at a 1000 or better. ( would this be a bad TPS?) or has this anthing to do with the fuel system. the car has tons of power and not stopping at 2200. Any suggestions would be a great help. I will admit its been fun working on it, but a little aggrivating to. Ivan. |
Re: 90 maxima maf ?
Originally no o-ring; if TPS box is sealed, then this closes one possible water route. 1. Did you tst TPS resistance, if its ok? 2. TPS zero pos sw needs adjustment... is it switching at 1k rpm? 3. Idle is adjusted warm, ECU sw turned in the process. Does the process hlp, work? 4. Small airleak causes hi idle as ECU increases injection to match airflow. Likewise Sticking IACV. 5. As MAF measures airflow, injection is controlled by its signal. Another MAF may be also faulty... (How does old MAF work, any difference?) 6. TB butterfly adjustment is ok, should be minimum clearance? ...so many changes have now happened, needs problem refocusing. Sit down and write down all things; is the problem now original, or self inflicted (very typical). |
Thanks again for any advise. Ivan |
