Old 05-19-2002, 05:17 AM
mattsbeamer mattsbeamer is offline
CI fuel injectors
Can any one explain the layout and the way a CI (compression ignition) diesel fuel injector works. Any pics. Thanks Matt.:silly2:
Old 05-19-2002, 07:19 AM
CraigFL's Avatar
CraigFL CraigFL is offline
Have you tried here:
http://www.howstuffworks.com/diesel1.htm
Old 05-20-2002, 08:45 AM
SaabJohan SaabJohan is offline
The injector sits were the spark plug usually sits if it were a gasoline engine. The diesel fuelpump is a mechanical pistonpump (one piston per cylinder) and have a pressure of around 1200 bars in modern diesels. Once every time the fuel is going to be injected the pressure is risen (the pump piston is pushed upward by a camshaft), when it reach a sertain point the injector will open.
Diesels usually don't have a throttle, it's only controlled by the amount fuel that is given, more fuel = more power. Since there is no throttle, the engine will run lean when it's not under full load.
Diesels are usually turbocharged since that will make them cleaner, a non turbocharged diesel will probably not manage todays exhaust emissions.
