Originally Posted by darocka2001
I have a 2003 Cavalier base model without the factory fog lights. I would like to install fog lights, preferablly the factory ones. I found a site that has them for $43 a piece. Question is how would you wire them up? Would I need to buy extra mounting pieces and wiring with a switch? If anyone has any knowledge on this it would be greatly appreciated. Also if anyone knows of any aftermarket fog lights that will fit in the housings on the bumper where the factory ones would go please post it.
Thanks.
well yes u will need wiring and a switch preferable with a fuse
well about aftermarket just look at the shape of ur bumper holes and look for any that might fit
is better to hook the positive to the battery directly but fused
and fix the switch wherever u want it.
in both lamps there is a common ground that u will hook to any metal around it so only the positive will go inside
