Old 10-10-2005, 02:27 PM
shaolyn shaolyn is offline
Send a message via AIM to shaolyn
a small swap
okay im doing this for a friend of mines and he has an 88 crx hf.. what im doing is puttin in a 88 crx si motor in for him.. would all the wires and things plug up?? they both are multi point fuel injected.. and would the hf tranny work with the si motor?? what clutch should i use an si or hf clutch in the hf tranny?? would i have to use an si axle?? thanx
90 nissan 240sx
Basically Bonestock...
Drop In K&N Filter...
243,000 miles on the odometer!!!
Still Runnin Haha
17' Racinghart CR5 Black Polished Lip
Old 10-10-2005, 03:55 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
Re: a small swap
the engine will drop right in, I'd suggest using the Si intake manifold if you can, its larger. The Hf tranny will work fine, depending on what flywheel you use the clutch will vary, if you use one from 90-91 its larger than 88-89.
With the Hf tranny you will need to use the HF axles and hubs.
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 10-10-2005, 04:41 PM
03TRDTacoma's Avatar
03TRDTacoma 03TRDTacoma is offline
Re: a small swap
not worth it to use the HF tranny. Try to find an Si one for about $150 tops at a junk yard. and use the Si axels as well.
2004 Toyota Tacoma 4x4
1990 Eagle Talon TSi AWD
2002 Suzuki GSX-R 600
Old 10-10-2005, 06:12 PM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
^^plus dx/si knuckles if you go that route
ZC stuff
http://dh-racing.com
http://www.thezcr.com/html/zcbook.php
http://dmoore.com/crx/zc.htm
http://www.jgenginedynamics.com/HOME%20PAGE
http://www.theoldone.com/
Old 10-11-2005, 10:02 AM
Re: a small swap
thanx for the info oh i have one more question.. you kno on the hf's there the black box on the firewall with the map vaccum lines on there.. would those work out or do i need to swap that out with a dx or si sensor/ vaccum...
90 nissan 240sx
Still Runnin Haha
Old 10-13-2005, 10:51 AM
Re: a small swap
bump
90 nissan 240sx
Still Runnin Haha
Old 10-13-2005, 11:00 AM
Hybrid1990crx's Avatar
Re: a small swap
map sensor lines should be the same. the hf tranny is gonna suck, i would try to find a si trans, my buddy is selling one in good shape if you are interested.
Old 10-14-2005, 02:52 PM
Re: a small swap
hmm how much for that tranny hybrid?? get at me
90 nissan 240sx
Still Runnin Haha
Old 10-15-2005, 02:54 AM
Re: a small swap
he just told me he might be selling it locally. ill let you know though.
Old 10-19-2005, 01:33 PM
Re: a small swap
ok well i got the motor in and everything is wired up it just wont start now.. it cranks over but not willing to start.. im fustrated now i dont kno what to do anymore someone please help
90 nissan 240sx
Still Runnin Haha
