Old 10-10-2005, 02:14 PM
KPot2004 KPot2004 is offline
my lt1 third gen plan
this winter i should be making about 400 every 2 weeks, if i budget that should leave me with about 250 or more to spend every 2 weeks
tubular lower control arms with poly bushings - $115
http://www.spohn.net/product.cfm?productid=1292
lower control arm mounting hardware - $10.95
http://www.spohn.net/product.cfm?productid=1408
adjustable torque arm 700r4 - $395.00
http://www.spohn.net/product.cfm?productid=1300
poly motor mounts - $39.95
http://www.spohn.net/product.cfm?productid=1363
KYB gr2 struts - $54.48 a piece
http://www.partsamerica.com/ProductD...ype=49&ptset=A
KYB gr2 shocks - $22.48 a piece
http://www.partsamerica.com/ProductD...ype=50&ptset=A
and the lt1 which i have seen them go anywhere from $400-$1500
together its about 716 + shipping for all the suspension parts.
any suggestions/ideas???. how much are the injectors for an lt1, since the engine i'll probably be getting will more then likely have some miles on it.
Teamsters Local 332
1998 GMC Jimmy, 4.3 Vortec V6, 80,000 Miles, K&N Filter
1992 Chevrolet Camaro RS, 355 TPI, Under Construction
Old 10-10-2005, 02:34 PM
drvngstorm05's Avatar
drvngstorm05 drvngstorm05 is offline
i thought you wanted a t56? that crossmember won't work for ya if you are going 6-speed... spohn does have t56 third gen crossmembers... and i would highly recommend spohn, that what i have... in face i have all of those spohn parts, except the 700r4 crossmember...
i would also recommend their sway bars... if you like to take hard turns like me...
'92 RS lt1/t56, lt4 hot cam, 30lb injectors, 54mm throttle body, full exhaust, 4.11 posi, 4 coil ignition, alluminum driveshaft, adj rear suspension, low. springs, electric water pump, custom tune.
Old 10-10-2005, 02:35 PM
oh and the spohn wonderbar is awesome too, i have that...
Old 10-10-2005, 03:15 PM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
Re: my lt1 third gen plan
What mods have you done to the LT1 so far?
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 10-10-2005, 03:21 PM
i am probably going to stick with the 700r4 for now just because of the cost involved with the tranny swap in having to buy a new crossmemebr.
and i dont have the lt1 yet, i dont have the money. and yeah i forgot to add the wonderbar, i want that too i figure $60 u canbt go wrong really.
and if possible i would like to be able to keep updating this thread, mods?? just so every time i have an update i dont have to make a new one.
i was paid today so next check is on the 24th thats when the first parts will be orderd. wish me luck.
Teamsters Local 332
Old 10-10-2005, 03:27 PM
Link85x Link85x is offline
Kpot, i read over at thirdgen.org that staying with the 700r4 (which can be done) is a biotch to deal with. Something about the ECM and VSS not working correctly (i forgot), and it's juts a pain to deal with. Are you looking at junkyards for your LT1, or purchasing from a private owner or ebay? I know swaping in the tranny can be expensive, but if you can possible get a whole donor car, it can make life easier, inside of nickel and diming each part. Suspension stuff sounds really good. Dave, i'll be doing up the whole suspension stuff aswell. I already got the 4th gen rear in there, and the sway is incredible small that came with it. What else should i get, hard turns are nice.
87 IROC - R.I.P, and she will never be forgotten
90 RS - The beginning of a new era... I hope.
oh and drvngstorm05 i remember reading that u bought an aluminum race radiator,how much was it and is there any chance u still remember where u bought it from???
Teamsters Local 332
Old 10-10-2005, 03:30 PM
link85, i'll have to read into that.. thanks for the heads up
Teamsters Local 332
Old 10-10-2005, 03:44 PM
Kpot, take at look at this
http://thirdgen.org/techbb2/showthre...hreadid=310714
i was thinking of keeping the 700r4 aswell because i didn't want to purchase another tranny, and was afraid of the cost of fixing a T-56 (i've check out prices on components, and if a complete rebuild is needed, you can spend over 2g's in parts, can get new one for a couple hundred less), but realized all the hassle you have to go to to keep the LT1 running properly with 700r4. It ain't worth it i guess...
Old 10-10-2005, 03:51 PM
ok if i go the 4l60e route, will the spohn 700r4 torque arm work??, if not i guess i'll go the t56 route. not sure yet.
Teamsters Local 332
Old 10-10-2005, 03:53 PM
I guess so, since people say the 700r4 and 4l60e are the same tranny, i think they have the same casing, just that ones mechanical and the other controlled by the computer.
Old 10-10-2005, 04:53 PM
woa, so many posts... give me a sec lol
ok get ready for a fuckin novel
like link said, it would be very much to your advantage to buy a donor car, not just an engine, and if you just want to go with the engine, i at least recommend an engine/tranny combo...
Link, as for suspension, since i can only really recommend what i have experience with, i recommend all the parts that kpot is talking about (cept the crossmember of course, you need a different one) plus the spohn racing wonder bar, 1in rear sway bar... i didn't upgrade my front sway bar cuz mine came factory with a 1 3/8in one which is more than enough, but look into a bigger front sway bar if yours came with a dinky one up front too... springs, struts and shocks are important, the ones kpot is looking at are good, but i'm a bilstien man, i have bilstien shocks and struts, and i have eibach lowering springs (1in front, 3/4 rear). aside from sticky tires the only other thing missing is subframe connectors (i'm getting them sometime). don't worry about a strut tower bar, the wonderbar performs the same task (in a different way) plus those can get in your way.
as for the 700r4, the only problem i would see would be the VSS (vehicle speed sensor) 4th gen vss's sent out much more pulses per revolution than 3rd gens did (that's why when i first got my car running my speedo read ten times faster than what i was going). plus, link doens't have to worry bout this, but the RS's came with speed sensor buffers, which have to be worked with to get the speedo right (we'll talk about that when the time comes i know exactly what you need to get to take care of it). the other possible problem would be if the harness you have came off of a 6-speed car, then the harness wouldn't work with your tranny... but as for the previous problem, you'll have to research but there may be a way to swap vss's from a newer 700r4 into yours... (although, i still strongly recommend getting an entire donor car)
as for the alluminum radiator, yes i got a 3in alluminum race radiator... for 300 off of ebay. however the issues i had with it are, if you look at your steering box, you'll see the power steering cooling line comes up then runs down in front of the box. once you put in a 3in radiator, there isn't clearance for in anymore, that's why i ran lines to the radiator's tranny cooler to use it as a power steering cooler. you don't have to have a cooling line, but i want to do some road racing, and in that situation you need something to keep the fluid from boiling. plus the third gen fan shrouds are not deep enough to cover the top of the radiator, so i have the lt1 fan shroud kinda jeery rigged to a third gen top fan shroud (with the aid of a hack saw lol) drilled out three holes, and using thin alluminum brackets, i attached the shrouds to each other...
700r4 and 4l60e have the same housing and the crossmember would work for both.
*takes deep breathe* wooo i don't mind writing this much, and trust me i'm pretty sure you'll be back on here once you get further along, and i'll be writing another haha
Old 10-10-2005, 05:26 PM
thanks a lot, i am sure ill be back on here too
Teamsters Local 332
Old 10-11-2005, 11:18 AM
Jcrane88 Jcrane88 is offline
Send a message via AIM to Jcrane88
i wish you luck..........i came across a old "hot rod" magazine that had a article about swapping a lt1 and ZF 6 speed or borg warner 6 speed into a 3rd gen camaro....and a few mods..the car runs 1/4's at 12.27...and it gets 26 mpg...it had a list of the stuff you need to do that swap....anyway it got me eyeing my camaro ...........good luck!
1984 Camaro 5.7L 350
700R4
Holley 650 Cfm
Edelbrock Performer Intake-Manifold
Crane Cams Duration @ .050": 204/214 Lift:420/442
Summit HEI Distributor
Hedman Shorty Headers
Hedman Y-pipe
Dynomax Turbo cat-back
NOS Decal
VTEC Decal
Old 10-11-2005, 12:14 PM
Originally Posted by Jcrane88
i wish you luck..........i came across a old hot rod magazine that had a article about swapping a lt1 and ZF 6 speed or borg warner 6 speed into a 3rd gen camaro....and a few mods..the car runs 1/4's at 12.27...and it gets 26 mpg...it had a list of the stuff you need to do that swap....anyway it got me eyeing my camaro ...........good luck!
that sounds about right
