Old 10-10-2005, 01:30 PM
dmunoz80 dmunoz80 is offline
Insufficient EGR Flow
I have a 98 Ford F-150 and the check engine light came on it is reading insufficient EGR Flow code 401 I changed the EGR Valve and the DPFE Sensor. I noticed that when i turn the truck off the EGR vaccum regulator makes a funny noise is this normal? Any suggestions would be appreciated!
Old 10-10-2005, 04:59 PM
transgta transgta is offline
Re: Insufficient EGR Flow
I went through this mine was the egr after i put dpfe on but check there should be two vaccum lines from dpfe sens to the exhaust. They are chrome on mine, mine was full of crap blow them out. Also make sure to disconnect battery or go to autozone to reset computer. As for the noise im not sure.
Old 10-11-2005, 01:00 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Did you clean the passages behind the EGR valve really good? These are bad about building up carbon in there.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-11-2005, 01:07 PM
86parky 86parky is offline
Re: Re: Insufficient EGR Flow
What is the best thing to use to clean out the carbon?
Old 10-11-2005, 01:52 PM
I did clean the passages but the only one i didnt clean was the line that goes from the EGR to the exhaust could this cause it. Also when i pull the vaccum line from the top of the EGR and check the vaccum the air stutters a little and isn't very strong is this normal? The only thing that i haven't changed is the EGR Vaccum Regulator could that be bad?
Old 10-11-2005, 02:31 PM
way2old's Avatar
TOKEN HILLBILLY
There should be no or very little vacuum on the valve at idle. You need a vacuum gauge and run the self test to see if the vacuum vent valve is operating properly. The way we clean the passages is to remove the throttle body and clean with solvent and a brush. You can do it with various cleaners. The noise may be a normal venting of the valve releasing vacuum after it is shut off. I have never listened for one, but the next one in the shop, I will do so. The vacuum vent usually trips a P0402 instead of a 401, but anything is possible.
Old 10-11-2005, 05:24 PM
Thanks I'll try cleaning it again any suggestions or preferences on what solvent to use for cleaning the throttle body? Also do you know where I can get an aftermarket transmission shift kit for the same truck?
Old 10-11-2005, 05:57 PM
way2old's Avatar
TOKEN HILLBILLY
Any carburetor cleaner can do the job. Check the net or a local trans shop to see if they have any kits.
