Go Back   Automotive Forums Car Chat > Mazda > RX-7
Old 10-10-2005, 11:54 AM
Wildcat2002 Wildcat2002 is offline
Losing coolant,overheating, exhaust gases in coolant...
I recently got a 1989 Maxada Rx-7 (no turbo) with an overheating problem. The engine as about 150,000 miles on it. It has had new coolant hoses, radiator, thermostat, etc. It runs a little rough and slowly oveheats within 10-15 minutes, especaily at freeway speeds. The temp gauge maxed out once (bad sign I hear) - but it did not boil over. A mechanic said there were exhaust gases in the coolant, but he also said it may be blown head gasket which I recently learned rotary motors do not have...
Basically, I think the car needs a new engine block due to an internal coolant leak. Before I chased one down, I wanted to make sure there is not an easier fix I should be considering for this problem. I'm not very familiar with rotary motors, but learning quickly. Thanks.
Old 10-10-2005, 12:41 PM
Capt.Moe Capt.Moe is offline
Send a message via MSN to Capt.Moe
Re: Losing coolant,overheating, exhaust gases in coolant...
To me it sounds like your motor gone and kicked the bucket with that many issues, I would vote on paying the 24-3400 for a new block.
Old 10-12-2005, 12:43 AM
drftk1d's Avatar
drftk1d drftk1d is offline
boost in, apex seals out
Send a message via AIM to drftk1d
REBUILD
RX-7 TII
Old 10-12-2005, 02:24 AM
Yeah, that's what I was saying.
Old 10-12-2005, 05:10 AM
FDTT FDTT is offline
Beofre you go nd blow a hole bunch of money on a new motor try to insta-fix trick. Some of the block sealer junk, i have heared many people extend the life of there rotaries with this junk. :P
Then when it blows, give me a shout.
Dont drive faster than your angels can fly
Old 10-12-2005, 01:07 PM
drftk1d's Avatar
Re: Re: Losing coolant,overheating, exhaust gases in coolant...
but in the end, thats like putting a band aid on a bullet wound
RX-7 TII
Old 10-12-2005, 09:58 PM
I don't even know if I would bother doing that. I mean, what is the point, if it goes after that or if it goes before then. If he bebuilds then the motor is reliable, or should be. Compared to Insta-junk.
