Old 10-10-2005, 11:45 AM
escort0526 escort0526 is offline
auto seat belts
Is it possible to clean or replace the switch in the door for the auto seat belts? Mine is working ok most of the time, but once in a while it takes a few minutes after I open the door before the belt gets the idea to move out of the way. Also, if I unhook the belt from the release it won't always hook back in without some coaxing.
Old 10-10-2005, 05:50 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
Re: auto seat belts
I had a door that did something like that and come to find out the door hinge pin was sagging once I put a bushing kit in the hinge the seat bellt worked fine.
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
Old 10-17-2005, 07:21 PM
AUTOUSA's Avatar
AUTOUSA AUTOUSA is offline
Re: auto seat belts
I disconnected mine so they do not move at all and you basically use them as regular seatbelts.....
Old 10-17-2005, 07:23 PM
AzTumbleweed's Avatar
AzTumbleweed AzTumbleweed is offline
Re: Re: auto seat belts
That's what I did too. Problem solved!
Nevada Tumbleweed
Old 11-02-2005, 10:04 PM
fanofelliottmjb fanofelliottmjb is offline
I was having the same problem. The controlling switch is in the latch of the door. Squirt some penatrating oil in it. They get dirty and gummy after a while.
Monte
Old 11-04-2005, 10:24 AM
Lynde Lynde is offline
Re: auto seat belts
Monte
I too had a similar problem it was the latch in the door, replaced it , works fine. But if you have a concern about connecting the seat belt to the track maybe the track buckle is distorted in some way? Try and see if you see something bent inside.
Old 11-08-2005, 02:43 PM
911escortGT 911escortGT is offline
i unhooked mine also and then i just leave the shoulder belt on and slip it over my head works great and its fast when you see a cop and also it looks like you are wearing it even when you are not thumbs up
My Ride
1991 ford escort GT, intimidator body kit, shaved door handles, body lines, roof channels , custom paint, under glow, with a kick ass stereo
