Old 10-10-2005, 06:57 AM
BGALLO BGALLO is offline
1992 4.3l Problem- Need Help To Diagnose
Hi,
My 92' S-10 truck with 4.3l throttle body is giving me trouble as of late, and I can't figure out what's going on. When I start it cold, it usually runs real rough, misses, hesitates and sometimes stalls. Once it warms up a bit it will run, but still has a miss to it and will hesitate or hit a flat spot or lurch when accelerating, especially under a load. Over the last week I changed; plugs, cap, rotor, fuel pump, fuel filter, and air filter. My computer is setting no codes either? Any help would be appreciated.
Old 10-10-2005, 09:08 AM
maxwedge maxwedge is offline
A990 racer
Re: 1992 4.3l Problem- Need Help To Diagnose
Scan it and look at the coolant temp sensor readings make sure thery correspond to air temp cold and warm up as the engine warms. Also check fuel pressure 10-13.
Old 10-12-2005, 11:54 PM
jackass#1's Avatar
jackass#1 jackass#1 is offline
Send a message via Yahoo to jackass#1
check timming, vacuum leaks, and maybe change out plug wires.
Old 10-13-2005, 06:18 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Sounds like typical CPI leaking... Pull your upper plenum and check for washing.
Old 10-13-2005, 01:43 PM
crazycory1 crazycory1 is offline
he has a tbi
Old 10-13-2005, 03:14 PM
rlith's Avatar
Originally Posted by crazycory1
he has a tbi
Ahh ok... Have you checked to make sure the nozzles are spraying a nice cone and not dripping?
Old 10-14-2005, 11:28 PM
bigd7315 bigd7315 is offline
Send a message via Yahoo to bigd7315
hey i have had the same prolem for 8 months and i have changed the coil , dist, wires ,plugs,fuel pump, fuel pressure reg, map sensor, fuel filter, esc unit, tps, idle air control motor, checked timing, replaced all vaccum lines, cleaned egr, cleaned injectors, and checked for other leaks with a vaccum gauge and i give up , changed all temp sensors and oil decending unit too so it is none of these on mine and i am still looking if i find the magic i will share
Old 10-14-2005, 11:49 PM
jackass#1's Avatar
have you checked into your battery and charging system.
Old 10-14-2005, 11:50 PM
I have a new battery and alternator replace them when i bought the truck
Old 10-18-2005, 11:31 AM
Thanks for all the responses. It turned out to be my ignition coil and plug wires. I had just changed them a year ago as routine maintenance, so I figured they probably were ok. Must have been cheap parts?
