Go Back   Automotive Forums Car Chat > Isuzu > General Discussion
Old 10-10-2005, 02:16 AM
gertman gertman is offline
Post Unknown Power Steering Part
I have a 1994 Trooper with a power steering leak. There is some kind of sensor attached to the pressure hose but does not show up on any parts list. It screws in and has two wires coming out of it. I also have a Chiltons service manual and there is no reference to this part in there either. Any ideas where I can get more information on this part?
Old 10-10-2005, 06:32 PM
Gizmo42's Avatar
Gizmo42 Gizmo42 is offline
It's the power steering pressure switch. When you turn the steering wheel the pressure closes the switch. If the engine is just idling the switch tells the computer to increase the rpm so the engine doesnt stall from the increased load (info from the Haynes manual).
Old 10-11-2005, 05:45 PM
Re: Unknown Power Steering Part
Thanks. The part is $140. But at least I know what it's for now. Does the Haynes book say anything about the installation? The part will not be here until Friday at the earliest.
Old 10-11-2005, 07:58 PM
Gizmo42's Avatar
Wow thats an expensive switch.
Haynes just says unplug the electrical connector, unscrew the switch, apply teflon tape or thread sealant to the threads of the new switch, install, plug in electrical connector.
Old 10-18-2005, 12:36 AM
Re: Re: Unknown Power Steering Part
Thanks for the help. Part's in and car is running fine.
Old 10-19-2005, 06:35 PM
Gizmo42's Avatar
Re: Re: Re: Unknown Power Steering Part
Glad everything worked out for you
