Old 10-10-2005, 12:10 AM
DjEarth DjEarth is offline
Squealing Issues
So in the past month we have replaced the front and rear rotors and brake pads. The front end is STILL squealing when I stop. Everything was cleaned properly before installed, everything was installed right. Yet I still have the damn noise!
I have searched through the fourm and can't find anything..is there somthing we missed..or are we missing some other problem all together?
Old 10-10-2005, 07:35 AM
rlith's Avatar
rlith rlith is offline
Send a message via AIM to rlith Send a message via MSN to rlith
Re: Squealing Issues
Did you spread ANTI-Squal on back of all of the pads? If so, did you grease the slidepins? Any play in your hubs?
Old 10-10-2005, 08:33 PM
wolfox's Avatar
wolfox wolfox is offline
Send a message via Yahoo to wolfox
Look for my post/article here. I hope it helps, the same treatment you give ceramic rotors can be applied to semi-metallic brakes which are stock on the older models. Also, NEVER replace pads on ANY of these trucks with full organic brakes. (The $20 box of cheapies)
http://www.automotiveforums.com/vbul...hlight=ceramic
Old 10-10-2005, 09:37 PM
drdd's Avatar
drdd drdd is offline
get a grease gun and grease all 11 grease fittings on your truck. Its too easy and cheap not to do. These trucks needs grease about every 3000 miles.
Old 10-14-2005, 08:48 PM
A local mechanic..that works for a Dodge dealership told me to pull the pads out and put a little bit of clear silicone on the back side of the pad and then put it back into place. He says the noise is a tiny vibration but makes a squealing like noise.
Says he fixed many veichles with new pads and rotors doing this..with this fix.
Haven't tried it yet, but will post the results here sometime in the next week.
Old 10-15-2005, 12:33 AM
BlazerLT's Avatar
BlazerLT BlazerLT is offline
AF -Advisor
Yea, that will act as an anti-squeal.
1995 Factory Blazer Service Manual for sale, PM if interested.
