| Off-Topic Talk about anything other than cars. |
water temp gauge
ok i installed my autometer water temp, everything seems to be working fine but my question is, what's the normal operation temperature? my car was at about 210 F all the time.
Re: water temp gauge
Depending on few variables like altitude, atmospheric pressure, outside temperature, and modifications on the motor, anywhere from 180F to 220F is normal. The autometer guage may be different, but the universal standard is that the needle should be slighly under half.
1993 Eagle Talon ES (4g63NA) 14.6 @ 98 mph (110 octane race fuel) -5 Speed Transmission (From a 4g67) -Stage 2 Crane cams -Ported and polished head -Aggresive valve springs -2.5" Custom made exhaust piping -Custom header -Gutted catalytic converter -Bored 0.5mm -Advanced ignition timing (CAS) aprox. 5 degrees (set @ ~10deg BTDC) -2g valve lifters (Lifter noise returned, now it a true DSM) -K&N w/modified air canister |
Re: Re: water temp gauge
-MODS-Autometer Boost,Oil Presure,And Water Temperature Gauges./Geddy Turbo Tmer/Eibach Sportline Springs Matched With Adjustable Iluminas 4 Corners/Konig 18" On Nitto Extreme 555/ACT 2100 PP with Street Disc/Extended Push Rod/Urethane Motor Mounts/XS Power FMIC. 28X10.5X3.5/Greedy Type RS BOV/ evo3 16g Turbo/MBC At 18PSI/Bian Crower 272 cams/SAFC2 With 510cc Injectors/Walbro 190 FP/ 1/4 mile=14.3@103MPH |
when you're actually driving you should see significantly lower temps. I mean on a highway though, not like stop and go driving, that's where the highest temps are (idling)
now - 2000 civic soon - 2002 is300
When fully warmed up, I run between 204 and 206. Sometimes after a hard 2 or 3 gear pull the temp will jump up to 208 or 210, but it immediately comes back down.
Sounds normal to me.
![]() 1997 Spyder GS-T 5-Speed EVO III 16g, DSMLink, Walboro 190 lph Fuel Pump, FIC 650cc injectors, CoolingMist 150psi Methanol Injection, Greddy EVO 2 Cat Back, 2.5" Extreme DP, 2.5" Extreme Hi-Flow Cat, Injen intake, HyperDrive C1 Street Disk & PP, HyperDrive Lightweight Flywheel, 1g BOV, RRE UICP, Home Depot MBC, AEM UEGO WBO2, Brembo Slotted rotors, Akebono Ceramic Pads |
I had a OBD-II scanner tool that hooked up to laptop. Kinda like DSM Link, but with no tuning. Just strickly sensor data. You could actually watch the coolant temp go up on the laptop when the data wasw downloaded to the computer. Kinda cool, because you could see exactly when the temp got hotter or cooler, depending on how fast you were going and all the other factors. It was so nice I returned it a few days later then.
2013 Chevy Sonic 1LZ Daily Driver, 1.4L Turbo, 6spd 75 Monte Carlo SBC 400 6.6L, Aluminum heads, Hurricane Intake... 12 Chevy Sonic 1LZ 1.8L - Traded 01 Pontiac Grand Am SE - RIP 95 Eagle Talon ESi-T 5spd - RIP 88 Oldsmobile Cutlass Ciera- RIP |
if you liked that, you'd love DSMLink
also keep in mind the ECU retards timing 1 degree at 210 degrees!
So, you want it cold then? Is this true with N/T 420a? Also, how can we get over that then?
you don't want it cold, you want it right in the operating temperature. Driving around temps shouldn't hit 210 and cause the ECU to retard timing. I don't know anything about the N/T's though, sorry.
