Old 10-09-2005, 05:28 PM
superman7967 superman7967 is offline
Send a message via Yahoo to superman7967
Power Steering Pulley Issue
I Have A 1998 Grand Prix Gt My Problem Is My Power Steering Pulley Came Off !!!! Does Anyone Here Know How I Can Fix It?
Old 10-09-2005, 06:03 PM
kok328 kok328 is offline
uhh .. bolt it back on?
Old 10-10-2005, 10:15 AM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Re: Power Steering Pulley Issue
the pulley is a press fit type. Did the pulley come off the shaft, or did the shaft shear off with the pulley when it left? If the pulley came off, did you recently replace the pump? IF so, it sounds as though the pulley wasn't pressed back on fully. In either case, if the pulley is gone, you need a new one. If you still have it and it isn't damaged, it needs to be pressed back on until the end of the pump shaft is flush with the end of the pulley.
