Old 10-09-2005, 05:19 PM
Wkendwrchr Wkendwrchr is offline
96 S10Blazer Starting Problem
The initial problem was the Blazer wouldn't start in the morning. The car will turn over but will not start. I can jump start the car and it will fire right up. This is what I know so far.
I've changed the fuel filter. I put a pressure tester on the fuel system and if I cycle the pump a couple of times I can get the fuel pressure up to 60psi which is the lower end of the recommended pressure.
If I cycle the fuel pump in the morning about 4 times I can start the car. Once the car is running there are no problems.
I've changed out the negitive cables thinking it was a bad electrical ground causing the problem. No luck.
I've replace the rotor and cap thinking it was an ignition problem . No luck
I replaced the fuel pump a couple of years ago and I don't have a problem doing it again if that the problem.
Any help would be appreciated.
Old 10-12-2005, 05:22 PM
movin2stereo's Avatar
movin2stereo movin2stereo is offline
Re: 96 S10Blazer Starting Problem
Very good chance it's the fuel pump,again.
Stickerchick.com,best decals on the net
Click here
My $12.00 Sunfire
Old 10-16-2005, 10:56 PM
10/16 Replaced the fuel pump this weekend and so far it seem to be running fine.
Thanks!
