Go Back   Automotive Forums Car Chat > Mazda > General Discussion
Old 10-09-2005, 04:15 PM
russiankid russiankid is offline
Send a message via AIM to russiankid
mazda b2200
ok, i dont know alot of mazda trucks but my friend has one and everytime you start it it runs for about 15 -30 secs then it idles and the idle is ruff and it dies, i took the air filter off and i noticed that the breather filter is pich black, also the air filter is dirty, could that cause the problem?i am also planning on using carb cleaner to clean the carb
Old 04-13-2006, 12:23 PM
hocbj23 hocbj23 is offline
Re: mazda b2200
Choke is not properly set, float in carb is not properly set. Cleaning carb with carb cleaner is OK but I would use Seafoam instead. Once carb is clean find a Haynes manual for truck and set carb choke and it should run much better.
