Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 10-09-2005, 04:22 PM
dickkers3472 dickkers3472 is offline
1988 735il rear suspension
Hi I'm new to these forums and i was wondering if anyone could help with a rear leveling system problem, the struts work well as they do not have more bounce then they need to but they sit low with no load, this is a european spec car and is in mint condition outside of the rear suspension problem any help would be greatly appreiciated.
Old 10-20-2005, 11:43 PM
AllGo'n'Show AllGo'n'Show is offline
Re: 1988 735il rear suspension
If you jack up the rear of your car or get some drive on ramps or borrow a lift from somewhere, look on your rear stabalizer bar. Took me a couple of seconds to find it but you will be hunting for a little U like metal pice with 2 bolts on the top that connects it to a rod that connects to the hydrolic acuator for the rear suspension leveling.
Now... if you have a drive on ramp or are on a drive on hoist, loosen those bolts, get 2-3 freinds and a full tank of gas, put them all in the car, turn the car on afte ryou loosened those bolts. and try turning the little U piece until the pump comes on and levels the car out to something more reasonable or until that dinging of the OBC stops *thats what made me fix mine in my case, damn dinging got anonying after awhile*
if you don't have drive on ramps or anything then you will have to go underneath, adjust it just a little bit, tighten, drop down, check and test, jack back up and change until your happy, which is why it would be worthwhile to go get a set of driveon ramps if you don't have any, they are only liek $30 from Wal-Mart.
