Old 10-09-2005, 03:07 PM
Powerefx Powerefx is offline
Throttle body swap
Hey yall, i just got a 3.8l throttle body and swapped it with my 1993 1.9l throttle body, its like an original mod for this car and seems to work for everyone. Im having a huge problem with the idle i believe. The car idels at 2500-3000 rpm on park or neutral. If im correct it should be at 1000. When i shift it into drive or reverse it decreases to 1500 rpm. I dont know what the problem could be, so first i disconnected the throttle and kickdown cablse and still the same problem. I was wondering what it could be, maybe the iac, or possibly the sensor on the throttle body itself(dont recall what its called) but i left the 3.8l sensor on it. Should i swap it with the original 1.9l's sensor? Need help asap, thnx.
Originally Posted by GTmike400
I think that you have one of the only cars that has absolutely no aftermarket parts.
Old 10-09-2005, 06:49 PM
chevyn0va1's Avatar
chevyn0va1 chevyn0va1 is offline
Send a message via AIM to chevyn0va1 Send a message via Yahoo to chevyn0va1
dont you still need to use the maf from the donor car?
1999 Escort SE 2.0 ltr sohc, 5 speed - old one
1999 Escort SE 2.0 ltr sohc, auto - new one
2002 Dodge Grand Caravan sport 3.3, auto
located in beautiful New England.
"You know failure isn't failure If a lesson from it's learned-I guess love would not be love Without a risk of being burned" ~ Garth Brooks
