Old 10-09-2005, 03:45 PM
gbic1 gbic1 is offline
90 28,000 miles backfires on hard accell
Got a 90 LeSabre down from the city. Wasnt driven most of its life. Has a very bad backfire and stumble on hard accell. If driven normally it runs like a new car. At take off from stop or when passing at highways speeds it will back fire through the air filter. Car has had new plugs, wires, fuel filter,cleaned MAF, seafoam 4 cans,catalytic converter and professional Motor Vac twice. We have repaired 3 vacuum leaks and unhooked the EGR valve. The car has no codes and with scanner on car every thing show normal. I cant believe it would be a timing chaim with this low of miles. Car just make a trip 1000 miles from florida because they wanted to sell him a 2200 dollar trans to fix the problem? Car had ecm changed a month ago for a iac problem but problem was there before ecm was changed. Car will run smooth untill you stand on it and will run 90 mph. Fuel pressure is fine. I would think a blocked screen in tank would keep it from running 90 mph.
1967 cougar 390 FE in progress
1993 F350 Crew Cab 5.8 111K
1983 Coachman 23ft class C 460
1988 Bronco 351 C6
1964 Galaxie 428 4sp project
1995 Mustang 3.8 Auto
1966 Mustang Fast back Project
1994 Tracer Trio 1.9
1968 F250 Camper Special 390
Old 10-10-2005, 05:31 PM
Gocart879 Gocart879 is offline
i would take a look at your spark. make sure all cylinders are firing properly at all times, i seems like a cylinder is malfunctioning. have your coil packs tested etc. i am sure someone else can elaborate from this point.
Old 10-10-2005, 07:33 PM
maxwedge maxwedge is offline
A990 racer
Re: 90 28,000 miles backfires on hard accell
It should be scanned to look for fuel trims out of whack, confirm proper o2 operation, check fuel pressure under load, do this first. remember a improperly installed wire or a cracked plug can do just this.
Old 10-10-2005, 08:02 PM
Believe it or not fuel trim looks good. Just got back from driving it with fuel gauge hooked up and it runs around 35 till you accell then it goes to 45 and stays steady. Wires are routed good and it is not just one cylinder it is leaning out on all. Just took of ground at bracket, cleaned connection and added star washer. It acts like bad MAF. Disconnected the ect to see if it would flood it out and it flooded it so bad it would not even start. It has the availability to get fuel but it just is not getting it.
1988 Bronco 351 C6
Old 11-05-2005, 10:44 PM
Let you all know that a stock replacement coil pack fixed this problem and I dont understand it but it is fixed.
1988 Bronco 351 C6
Old 06-23-2006, 04:05 PM
dcmtnbkr dcmtnbkr is offline
Because the coil packs on the original 3800's overheat. Heavy acceleration will cause this especially in older moldels. If anybody else needs help with this, i hear that you can swap the coil packs with the coil packs off of a series 2.
