Old 10-09-2005, 02:39 PM
Movieguymookum Movieguymookum is offline
Send a message via Yahoo to Movieguymookum
Rear-end questions, help??
How can I tell if I have a full-floating or semi-floating axle? And is there a way to tell the ring gear size, 8.5 or 9.5 without pulling the cover and physically measuring it? The code in the glove box is GU6 and I know the axle ratio is 3:42, a posi trac and it is a ten bolt cover.
Thanks for any help you can give.
Old 10-09-2005, 03:49 PM
maxwedge maxwedge is offline
A990 racer
Re: Rear-end questions, help??
If it was full floating you would see the hub and bolts on the end of the axle. 9.5 is the large axle most likely in the 3500 series only.
