Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Closed Thread Show Printable Version Show Printable Version | Subscription Subscribe to this Thread
Old 05-18-2002, 07:01 PM
JgainesIA JgainesIA is offline
Send a message via ICQ to JgainesIA Send a message via AIM to JgainesIA
What is the difference in 1st gen gsx/gst engines and 2nd gen
Overall differences? HP? Turbo diff?
If it feels good, do it
Old 05-18-2002, 07:06 PM
Got Boost?'s Avatar
Got Boost? Got Boost? is offline
Banned
the 2g have alittle more power but the 1g are more reliable,you can find out more at www.clubdsm.com
Old 05-22-2002, 12:34 AM
GSXer GSXer is offline
Actually, the 1st gens have bigger head poirting and and somewhat of a stronger bottom end. HP is rated at 195hp. Don't let that fool you though, its capable of withstanding 600hp with stock inernals. It also comes with the trusty 14B turbo. Head flows alot morte air. Some of the motors also have different cam angle sensors. The throtle body is bigger along with the intake manifold.
2g's have almost the exact settings, only differences are the turbo (T25 a.k.a T2small) and head work is a little more constictive. Also it has the 7 bolt motor which has the nasty reputation to suffer from crankwalk. Odds of happening to you are slim to none. But it may still happen....there alot more, but I'll let you do your homework...Have fun
Old 05-22-2002, 12:35 AM
BTW, the bottom end of a 2g can withstand 400-500 hp stock as well. 4G63's are the bomb!!!!!!
Old 05-25-2002, 11:12 PM
ECTurboGSX ECTurboGSX is offline
Send a message via AIM to ECTurboGSX
Alrighty, here goes. This is my first post here, but I hope I can help answer questions through my experience.
First Gens:
Better- Head, turbo (14b), Throttle body (60mm), Rods, Short Block (6 bolt), Intercooler core is bigger, intake manifold, compressor bypass valve, and the later 1st gens had the 4 bolt rear end.
Second Gens:
Better- Pistons, Throttle Body Elbow, Mass Airflow Sensor, Exhaust Manifold, larger intercooler endtanks, O2 Housing
I think I got most of it, and I will edit it as I think of more.
Eric
1990 Mitsu Eclipse GSX
13.4 @ 102.9
Big 16G @ 19 psi
Old 07-11-2002, 02:01 AM
talondvr talondvr is offline
1st gen has the stronger bottom end larger head and better 14b turbo.
2nd gen switched to a smaller garrett turbo that gives a smaller psi rating
Old 07-11-2002, 03:18 PM
The 2nd Gens making more horsepower is simply the compression, which was 7.8:1 in the first gen and 8.5:1 in the second gen.
Eric
13.4 @ 102.9
Big 16G @ 19 psi
Old 07-28-2002, 02:31 PM
Rob80 Rob80 is offline
Send a message via AIM to Rob80
can you swap a 14b into a second generation. I mean is it a direct fit?
Old 10-15-2006, 08:35 PM
kiesha15 kiesha15 is offline
Question Re: What is the difference in 1st gen gsx/gst engines and 2nd gen
Did any one anwser your last question about the fit? I'm trying to put a 2gen into a 1st (a 7 bolt into a six bolt placement)
Old 10-15-2006, 08:42 PM
Blackcrow64's Avatar
Blackcrow64 Blackcrow64 is offline
And this thread is almost 4 years old... Do NOT bring back dead threads unless you are the original poster to the thread.
-Brian
  • 92 Firebird sold
  • 97 Talon TSI AWD sold
  • 05 Cobalt LS sold
  • 02 Tahoe LT sold
  • 06 Cadillac STS4 AWD sold
  • 03 Corvette Z06 sold
  • 14 Silverado 1500
  • 26 Equinox RS
Closed Thread
