Old 10-09-2005, 12:37 PM
mrecor10 mrecor10 is offline
Electrical
Volt and Air bag lights flash and car seems to surge. Changed tension pully and belt still surges and seems like the electrical system is low and then back to normal. Help !
Old 10-09-2005, 01:02 PM
cadgear's Avatar
cadgear cadgear is offline
Re: Electrical
Did you check the alternator? Sounds like its trying to whack out on you. Also check to make sure battery cables are -clean- and secure.
Old 10-09-2005, 02:12 PM
Re: Electrical
Tried it. Still no luck. Volts light is staying on untill I rev it up for a minute and then it goes off.
Old 10-09-2005, 02:50 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: Electrical
I'm almost sure the alternator is your problem. You can take it out, and bring it in to have it bench tested. I know some places will do that for you. They will even bench test it and put a load on it. More than likely your alternator is your problem.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
