Old 10-09-2005, 12:19 PM
mcmahonm8run mcmahonm8run is offline
Clutch pedal stuck
I own a 1999 v6 manual 3800 series camaro. My problem is whenever I depress the clutch to switch gears, the clutch pedal becomes stuck and I have raise back up with my foot. Please Help. I have tried using WD-40 to lubicate the joint and the clutch fluid is filled. Thanks Ladies and Gents!
Old 10-09-2005, 12:53 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Sounds like a problem in the master cylinder, probably needs to be rebuilt or replaced. Rebuild kits are inexpensive, and they are pretty easy to rebuild, its just a little difficult taking it out as there isn't alot of room to move around down there.
Old 10-10-2005, 09:00 PM
goldz28's Avatar
goldz28 goldz28 is offline
Re: Clutch pedal stuck
It could be the slave also. My slave went out and the pettle went to the floor and would not come up...... It needed some viagra. Cost about 400 bucks
2008 G8 GT ~ 2004 Silverado LT ~ 1998 z-28
Tuned By TJ Wong - Wong's Performance Engineering
Old 10-11-2005, 10:38 AM
Xenostalgia's Avatar
Xenostalgia Xenostalgia is offline
Send a message via AIM to Xenostalgia
check your fluid, see if its low. its behind the firewall behind the drivers side kinda steering wheel area. You'll see two reservoirs. One big one (brake) and one small one behind it (clutch)
Originally Posted by 97CamaroRS
You know he's cruisin in the GN above us - RIP, Andy
Be Warned....
Originally Posted by twospirits
what your name really means...
XENO...
Xtreme
Emotional
Neurotic
Ominous
www.Xenostalgia.com Exit your Reality || 97 Acura Integra GS 2DR
Old 10-16-2005, 12:23 PM
Thanks for Inputs
Thanks for all of your inputs. I will look into each one of them. You don't know how much of a help you all have been! Thanks and drive CAMARO!!!!!!!!!!!!!!!!!
