Old 10-09-2005, 11:33 AM
transgta transgta is offline
What Does The Neutral Switch Do????
My 01 supercrew is shifting funny after rebuild. After going back several times the guy is telling me the neutral switch is causing it this is his guess. Does anyone know if that can cause funny shifting. Heres what it does when it shifts its kinda like if you would push in the clutch change gear then slowly let out on clutch but its automatic. This is a 70 dollar guess so i need output please.
Old 10-09-2005, 11:58 AM
badassfocus1101 badassfocus1101 is offline
Banned
Send a message via ICQ to badassfocus1101 Send a message via AIM to badassfocus1101 Send a message via Yahoo to badassfocus1101
Re: What Does The Neutral Switch Do????
could be the torque converter
Old 10-09-2005, 11:59 AM
Banned
is there any clunkin when it shifts???
Old 10-09-2005, 05:21 PM
There is no noise just a slow shift only does it mainly from 2nd 2 third doesnt hardly do it when it hammerd but trying 4 gas mileage ive slowed down
Old 10-09-2005, 05:36 PM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
The neutral switch also tells the PCM which gear you are in and when to shift. If it started after the rebuild, I would be suspicious of internal clutch clearances being off. You can mark the switch, loosen it a little and re-tighten to see if it helps any. If adjusting the position of the switch cures the problem, replace it. If it does not help, problem is more than likely inside the trans.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-12-2005, 09:27 PM
Ok when i loostened the two bolts and twisted the module a little then re tightened it shifted a little better for a little then seems to be right back where it was. Im thinking what ur saying is replace it correct.
Old 10-13-2005, 12:01 PM
way2old's Avatar
TOKEN HILLBILLY
I think that may be a first step. Or you can have it diagnosed at a trans shop. A lot of big chain shops give free estimates and diagnosis.
