1995 z28 or ss?
which has more power, and shorter gears? do 4.10s go straight in?
thx |
the ss didnt come back until 1996 and was rated at 305 hp and 325 ft/lb torque, the 95 z28 was rated at 275 hp and 325 ft/lb torque. the 96 ss auto had 3.23 gear ratio and the 6 speed had 3.42. the 95 z28 auto had 2.73 with an optional 3.23 and the 6 speeds had 3.42. im not sure about the 4.10 rear end swap but i wouldnt imagine there would be too much of a problem.
Re: 1995 z28 or ss?
Couple of things are incorrect there but very close. Any auto SS or Z28 LT1's could have either 2.73's or 3.23's (or even very rare 2.93's , ask DVS) Nearly all manuals have 3.42's (but a select rare few have 3.23's) The Z28 and SS are actually alot closer to the same power than is advertised, a stock LT1 6 speed Z28 will average between 250 - 255 Horse at the rear wheels, when you calculate in drivetrain loss, you can see they were under rated much like the LS1. Also 4.10's will fit in any 3 series differential which is 3.23's and ^, any 2 series ratio which is 3.08 and v will require a spacer or a differential change.
RIP Hypsi - I just want to express I will never be the same after having lost such a good friend. You meant alot to me and I feel I am a better person for having known you. Til the day we meet again my friend you will always be in my heart. Mods: Weight reduction (I don't wear underwear) |
thanks for helping me out and clearing some stuff up....i was just going by what camarosource.ca had hp ratings at and http://www.f-body.org/tech/4th_gen.htm for the gear ratios but its an old site.
Re: 1995 z28 or ss?
Well that site's way off cause I can also tell you that I took 3.08's out of Kasey's 97 Camaro 3.8 and that isn't on the list either. So its just stating the more commen ratio but not all the possibiltys
Re: 1995 z28 or ss?
i have 3.23's but that was swaped in
![]() Quote:
alright thx...where would i buy gears at?
Re: 1995 z28 or ss?
