Go Back   Automotive Forums Car Chat > Nissan > Murano | FX45
Old 10-09-2005, 12:44 AM
Rrroman Rrroman is offline
Question 'Rotational noise' at low speeds
I have a 'rotational' noise when I drive my fx35 at low speed, up to maybe 35mph. I started noticing the change in sound about at 36000 miles like 3 or so months ago. I know I need to get new tires real soon and maybe even new front brakes but I don't think it is either of these 2 things that's really the cause of the sound. It may also be causing some friction. Does anyone else have this problem? What else may be causing it? Uneven caliper/brake compression on the rotars? Also the brakes on the inside/rear of the front calipers are worn out alot and the ones on the front/outside are barely worn out. What the ...?
Old 10-13-2005, 12:28 AM
jackiec1976 jackiec1976 is offline
Send a message via Yahoo to jackiec1976
Re: 'Rotational noise' at low speeds
I have that problem as well, but I do not know what it is either. Would love to hear a reply from someone who does know.
Old 03-23-2006, 12:18 PM
SiggyBaby SiggyBaby is offline
We are having a problem that could be related to that. I posted a thread in here on it too.
http://www.automotiveforums.com/vbul...d.php?t=541876
Old 03-23-2006, 06:22 PM
FixUrNissan's Avatar
FixUrNissan FixUrNissan is offline
there are a couple of things you can try
1 , If you need new tires , Try that , Cause you know you need them anyway
2 , If the noise is still there , It could be a Wheel Bearing if it a deep piched Growling noise that gets more pronouced taking turns.
3 , Breaks can give you noises , but it doesnt sound likely in this case.
Try 1 first.. then see if 2 applys if not move on to 3
